Trouble configuring VLAN for guest wireless
J W
Hello. I am wondering if someone can point me in the right direction here. I am attempting to configure a VLAN for a guest wireless network at a clients site.
The AP will be a procurve 420 that has a guest SSID and a VLAN set up on it (Vlan240) it is set to tag the packets with the VLAN info.
I have this device plugged into a Cisco 1711 router, into FastEthernet 2, on the built in switch port. My goal here is to have it set up so when someone connects to the Guest SSID, they are tagged with VLAN240, and they then obtain an IP address from the DHCP servicerunning on the 1711. If they jump on with the secured side, then they obtain an IP from the DHCP server in the DC. I have an ACL written to deny traffic from the 192.168.240.0 network to anything on the 10.0.0.0 network (Secured)
The trouble I am having is that when a user jumps on the guest wireless, they obtain an IP from the secured side (10.0.0.0). I am not sure if it is even seeing the VLAN info.The config may be a bit messy now as a result of my trying to troubleshoot the issue. I have tried moving the IP address (192.168.240.1) to the VLAN interface, instead of F0.240, but that does not help either. What am I missing?
Below is my config info (I have ensured that VLAN240 is in the VLAN database on the 1711
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 64000 warnings
enable secret XXXXX
username XXX password 7 XXXX
clock timezone EST -5
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip source-route
ip dhcp excluded-address 192.168.240.1 192.168.240.2
ip dhcp pool Pool1
   network 192.168.240.0 255.255.255.224
   default-router 192.168.240.1
   dns-server 10.0.1.2 10.0.1.3
ip dhcp pool pool1
   domain-name XXXX.local
ip tcp selective-ack
ip tcp path-mtu-discovery
no ip domain lookup
ip domain name XXXX.local
no ip bootp server
ip cef
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 icmp
ip ips po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
ftp-server enable
no ftp-server write-enable
ftp-server topdir flash:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXX address XXXXX
crypto ipsec transform-set SDM_TRANSFORMSET_1 esp-3des esp-sha-hmac
crypto map SDM_CMAP_10 1 ipsec-isakmp
description Tunnel to SAM Datacenter
set peer XXXX
set security-association lifetime seconds 28800
set transform-set SDM_TRANSFORMSET_1
match address GRE2DATACENTER
interface Tunnel0
description VPN to SAM Datacenter Fiber
bandwidth 3000
ip address 10.254.253.82 255.255.255.252
no ip redirects
no ip proxy-arp
ip mtu 1338
ip hello-interval eigrp 10000 20
ip hold-time eigrp 10000 60
ip route-cache flow
ip tcp adjust-mss 1200
cdp enable
tunnel source FastEthernet0
tunnel destination XXXXX
interface Null0
no ip unreachables
interface Loopback100
ip address 10.254.1.82 255.255.255.255
no ip redirects
no ip proxy-arp
ip route-cache flow
interface FastEthernet0
description Connected to Internet
ip address <External IP> 255.255.255.248
ip verify unicast reverse-path
no ip redirects
no ip proxy-arp
ip nat outside
ip inspect DEFAULT100 out
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
crypto ipsec df-bit clear
interface FastEthernet0.240
encapsulation dot1Q 240
ip address 192.168.240.1 255.255.255.0
ip access-group 130 in
ip helper-address 192.168.240.1
no ip redirects
no ip proxy-arp
ip nat inside
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
switchport mode trunk
no ip address
vlan-id dot1q 240
  exit-vlan-config
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
no ip address
no cdp enable
interface Vlan1
description Connected to SAM LAN
ip address 10.1.40.1 255.255.254.0
ip helper-address 10.0.2.11
no ip redirects
no ip proxy-arp
ip nat inside
ip route-cache flow
interface Vlan240
no ip address
no ip redirects
no ip proxy-arp
vlan-id dot1q 240
  exit-vlan-config
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
router eigrp 10000
passive-interface FastEthernet0
passive-interface Vlan1
network 10.0.0.0
no auto-summary
eigrp stub connected
ip classless
ip route 0.0.0.0 0.0.0.0 10.254.253.81
no ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 150 interface FastEthernet0 overload
ip access-list extended GRE2DATACENTER
  permit gre host <LOCAL WAN ADDRESS> host <Dest. Tunnel WAN Address>
access-list 1 remark Auto generated by SDM Management A0.1.30.1 eq telnet
access-list 101 deny   tcp any host 10.1.30.1 eq 22
access-list 101 deny   tcp any host 10.1.30.1 eq www
access-list 101 deny   tcp any host 10.1.30.1 eq cmd
access-list 101 deny   udp any host 10.1.30.1 eq snmp
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 125 permit esp any any
access-list 130 remark Deny access to the 10 network for guest wireless.
access-list 130 deny   ip any 10.0.0.0 0.255.255.255
control-plane
line con 0
login local
transport output telnet
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
no exec
transport input all
transport output none
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
andrew.prince
Level 10
Level 10
I can see 2 config issues:-
Not required, as the DHCP server is local - this is only required when the DHCP is elsewhere on another IP subnet.
By default ANY access list has a deny any any at the end - this is default and you do not see it.  So your ACL will block all traffic.
The fact that the clients are receving an 10.x.x.x IP address indicates 2 issues:-
1) The AP is not tagging the layer 2 traffic with the correct VLAN ID.
2) The switch port the router is connected to is not a trunk.
HTH>
Thank you for the suggestions! I realized that ip-helper address was not necessary and have since removed it. As for the acl, my goal was to block access from the guest network (192.168.240.0) to the secure network (10.0.0.0). Wouldn't the access list as configured just block traffic as described, or am I off on that one?
I will try changing the encapsulation command and see if that helps too! Thank you for the suggestions.
t_mcwilliams
It seems everything coming in from FastEthernet2 is untagged. Not sure if this will help much but try removing the "vlan-id dot1q 240" from the interface and add "switchport trunk encapsulation dot1q".
