Trouble with VPC Keepalive Link
johnnylingo
Level 5
Level 5
Trying to setup a VPC between two Nexus 5548s.  They are connected via a SFP-H10GB-CU3M cable, with the ports left in vlan 1.
# Nexus 1
interface Ethernet1/3
  description VPC keepalive
interface Vlan1
  no shutdown
  vrf member vpc_keepalive
  ip address 172.16.1.1/30
# Nexus 2
interface Vlan1
  no shutdown
  ip address 172.16.1.2/30
But, the VPC keepalive isn't working:
# show vpc peer-keepalive
vPC keep-alive status             : peer is not reachable through peer-keepalive
--Send status                   : Success
--Last send at                  : 2013.12.13 15:03:31 753 ms
--Sent on interface             :
--Receive status                : Failed
--Last update from peer         : (661074) seconds, (328) msec
vPC Keep-alive parameters
--Destination                   : 172.16.1.2
--Keepalive interval            : 1000 msec
--Keepalive timeout             : 5 seconds
--Keepalive hold timeout        : 3 seconds
--Keepalive vrf                 : vpc_keepalive
--Keepalive udp port            : 3200
--Keepalive tos                 : 192
johnnylingo
Level 5
Level 5
Well I think I found the problem:
# show int vl1
Vlan1 is down (suspended), line protocol is down
  Hardware is EtherSVI, address is  002a.6a23.003c
  Internet Address is 172.16.1.2/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
Was able to fix this by removing vlan 1 from the VPC Peer link, rebooting, then re-builting the VPC peer link.
