Troubleshooting Cisco ISR
damar1010
Hello. I am currently using two cisco Integrated Services Routers to set up communication between two networks. I was unable to push any traffic through the FE 1/1-7 ports so I put a static ip on my fa 0/1. I plug a dummy switch into the 0/1 on ISR 1 and I can ping the transport on ISR 2 from one of the hosts on that dummy switch. I have setup a trunk from 0/4 on the router to 1/8 on the switch. My sh commands confirm that the trunk is up. I ran cdp. Still no traffic. I cannot even ping the 0/0 from the 1/1.
Reza Sharifi
What type of Cisco device is this and what is the part number for the module that is installed?
Also, what version of IOS are you running?
The M3-SE3 which contains a Cisco® 5915 Embedded Services Router (ESR) and ESS 2020 switch cisco version 15.2.
