Troubleshooting interface traffic on port 120 using access-list mapped to interface
getaway51
Level 2
Level 2
I have a WAN interface Gi0/0.
May I know I i wanted to check outgoing and incoming traffic in port 120, how does the inout/output config of access-list mapped to interface looks like? The objective is to prove tht router is forwarding traffic via port 120. I guessed also to prove other side (202.155.0.0/17 or ANY) is not sending traffic over via port 120 as well.
Traffic Output
Source is WAN interface IP or exact IP is needed?
Destination is 202.155.0.0/17
Port is 120
Traffic Input
Source is 202.155.0.0/17 or ANY
Destination is Gi0/0 or exact IP is needed?
Port is 120
Many thanks guys!
Giuseppe Larosa
Hello @getaway51 ,
in writing IP ACLs even extended we need to use IP addresses
The second important aspect is that the port 120 has to follow the server side
So if the traffic is originated from your GE IP address TCP port 120
access-list 110 remark outgoing ACL
access-list 110 permit tcp host <Gi0/0-IP-address> eq 120 202.155.0.0 0.0.127.255
access-list 110 permit ip any any
access-list 111 remarki inbound ACL
access-list 111 permit tcp 202.155.0.0 0.0.127.255 host <Gi0/0-IP-address> eq 120
access_list 111 permi ip any any
if the TCP server were in the 202.155.0.0/17 the position of the eq 120 would be reversed (as noted above it follows the server side)
you then apply the ACLs to your GE
interface gi0/0
ip access-group 110 out
ip access-group 111 in
Hope to help
Giuseppe
If unsure it is udp or tcp, can we apply both udp and tcp in the ACL like below?
access-list 111 permit udp 202.155.0.0 0.0.127.255 host <Gi0/0-IP-address> eq 120
Thanks!!
Hello @getaway51
yes you can  one line for TCP one line for UDP and the explicit permit any to avoid to black hole all other traffic.
Hope to help
Giuseppe
