troubleshooting
jonk34567
Level 6
Level 6
what feature you should use to analyse and monitor your traffic for troubleshooting ?
A. RSAPN
B. SPAN
C. Netflow
D. SNMP
what is/are the answer?
lucaslara
Level 2
Level 2
A,B,C and D
what is the most suitable ?
Julio E. Moisa
I think it is a tricky question, because all of the options are useful for troubleshooting, now if you want to collect data to be analysed it could be: A, B and C
Note: I assume the option A has a typo, it should be RSPAN (remote span) otherwise the answer could be: B and C.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
@Julio E. Moisa Good Point!
probaly could be a tricky question.
