Trunk - 2xVlan WS-C2960G-8TC-L
trexen1977
Hi all,
my first question here =)
i got 2 of thoes in topic, between my office and a customer whit fiber connection and some fiber-to-TP converter.
i also use Nagios to ping and moniton my devices, the switches is configured exatly the same but different ip.
The problem is that one of the switch goes down a couple of times a day, very annoying. i cant se anythin in the loggs, and im not sure i have done the configuration right, if someone can have a look at it, other possibilities is that the IOS have some bug, i dont have a cisco account to download new ios =(
IOS=12.2(35)SE5
(c2960-lanbasemz.12235.SE5)
Marcus, SE
garytayl
Level 3
Level 3
Your configuration seems fine (pretty simple config). One question, when you say switch goes down you mean the switch itself or the port of that switch is the one that goes down?
If is the switch, is better to configure a syslog server with the hope we can gather any errors before it goes down again. If the interface, do you see any errors on that port? Let us know
Thaks for fast answer.
Sounds good to know that config file look fine, sorry, i think is the port that goes down not the whole switch.
I can se that port 1, 4 and 7 goes down sometimes in the log
Port 1 is a computer in vlan 60
Port 4 is a router in vlan 80
Port 7 is Trunk between switches
i will try to config a syslog server right away and post the output
Marcus
Marcus, try to get us the output of show interfaces of those three ports (1,4,7). Since the switch is not the one going down, capturing the show log for us should be enough.
