Transmit discard : what is his cause
connect101
What are the reasons that an interface display "Transmit Discard"?
Thank you
garytayl
Level 3
Level 3
Are caused by a congested interface. The ultimate solution to resolve the problem is to increase the line speed. You can prevent them only if those are consequence of short bursts of data (if line is capable of full-duplex making sure it is set to full and not to half for example).
If caused by a constant high-rate flow, you cannot prevent them.
