trunk 3750 and 3850
jdiaz
I have a 3750 stack as my core switch in my Atlanta location. We recently purchased a new 3850, but I can't ping back and forward between them. They do see each other as CDP neighbors. Here is my setup
3750 -> core switch (10.11.1.2 - gateway)
garfield#sh ip int br | ex un
Interface              IP-Address      OK? Method Status                Protocol
Vlan10                 10.11.1.4       YES manual up                    up
Vlan41                 192.168.41.10   YES manual up                    up
Vlan112                10.11.2.7       YES manual up                    up
Vlan172                172.16.1.2      YES NVRAM  up                    up
Vlan192                192.168.40.4    YES manual up                    up
Vlan310                10.3.3.3        YES NVRAM  up                    up
garfield#
Ran these commands to create port chann:
int Gi1/0/49 & Gi2/0/49
shut
switchport
channel-group 10 mode active
exit
int port-channel 10
switchport trunk enacap dot1q
switchport mode trunk
exit
int gi 1/0/49
no shut
int gi 2/0/49
no shut
end
Port-channel10 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0019.e78d.cc31 (bia 0019.e78d.cc31)
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 0/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi1/0/49 Gi2/0/49
  Last input 00:14:36, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     52181 packets input, 6623363 bytes, 0 no buffer
     Received 52039 broadcasts (51920 multicasts)
garfield#sh int port-chann 10 switch
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
garfield#sh int port-chann 10 trunk
Port        Mode             Encapsulation  Status        Native vlan
Po10        on               802.1q         trunking      1
Port        Vlans allowed on trunk
Po10        1-4094
Port        Vlans allowed and active in management domain
Po10        1,10,41,70,72,110,112,172,192,222,310,400,410,722,999
Port        Vlans in spanning tree forwarding state and not pruned
garfield#
Here is the config on the 3850 side:
The 3850 has an IP address of 10.11.1.14 and IP routing is disabled (not sure if it needs to be).
Jon#sh ip int br | ex un
Vlan1                  10.11.1.14      YES NVRAM  up                    up
Jon#
Jon#sh int port-chann 11 switchp
Switchport: Enabled
Voice VLAN: none
Port-channel11 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 6cfa.8961.aeb1 (bia 6cfa.8961.aeb1)
  MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
  Members in this channel: Gi1/1/1 Gi2/1/1
  Last input 00:00:00, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Output queue: 0/40 (size/max)
  5 minute input rate 9347000 bits/sec, 1532 packets/sec
     1162869640 packets input, 849966959309 bytes, 0 no buffer
     Received 444658674 broadcasts (421043246 multicasts)
     0 watchdog, 421043246 multicast, 0 pause input
Jon#sh int port-chan 11 trunk
Po11        on               802.1q         trunking      1
Po11        1-4094
Po11        1,10,41,70,72,110,112,172,192,222,310,400,410,722,999
What am I missing? I want to be able to use all my vlans on both switches. The fiber is connected, the ports are trunked, and the port-channel is up. At this point, I would have expected to be able to connect a laptop on the 10.11.1.x  subnet (10.11.1.120) to the new 3850, and ping a server on the same subnet (10.11.1.100) connected to the 3750. Instead, I get no reply. I can't ping the gateway (10.11.1.2 - 3750) either. The only ping reply I get, is if I ping the new switch (10.11.1.14), which is where the laptop is plugged in. I didn't think this setup would be complicated, but it's entirely possible that I missed some basic thing. I'm in no way a cisco expert, so I turn to you all for help.
Any assistance is appreciated.
Thanks.
JD
JD,
Based on my recent similar issue i recommended to reboot.
Okay lets try this:
1- Default all the interfaces on both the boxes or remove the port-channel.
2- Reboot the 3850.
3- Configure the Port-channel first
4- Shut down the Physical interfaces on both the side.
5- Configure the physical interfaces by applying all the config.
6- Unshut the physical ports.
Let me know how this goes.
7 Replies 7
Leo Laohoo
Wierd.  I've never seen an output like this before.
Can you post the output to the command "sh etherchann <10 & 11> summary"?
Hi Leo, and thanks for your reply.
I've made a change, so now each switch has the same port-chann number (10). Here is the new output, plus the config you requested:
on the 3750 (core):
garfield#sh etherchann 10 summ
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
10     Po10(SU)        LACP      Gi1/0/49(P) Gi2/0/49(P)
garfield#
garfield#sh int port-chan 10
  Last input 00:04:15, output 00:00:00, output hang never
     65862 packets input, 8361474 bytes, 0 no buffer
     Received 65720 broadcasts (65567 multicasts)
     0 watchdog, 65567 multicast, 0 pause input
     177085397 packets output, 156101710776 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
garfield#
On the 3850 (new):
Jon#sh etherchann 10 summ
        d - default port
10     Po10(SU)        LACP      Gi1/1/1(P)  Gi2/1/1(P)
Jon#
Jon#sh int port-chann 10
  Hardware is EtherChannel, address is bc67.1c2c.8f31 (bia bc67.1c2c.8f31)
     reliability 255/255, txload 1/255, rxload 255/255
  5 minute input rate 2812328000 bits/sec, 478213 packets/sec
  5 minute output rate 1604000 bits/sec, 2809 packets/sec
     1211931813 packets input, 892022933648 bytes, 0 no buffer
     Received 476891456 broadcasts (452887224 multicasts)
     0 watchdog, 452887224 multicast, 0 pause input
     7131294 packets output, 511555866 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Jon#sh int port-chann 10 trunk
Po10        1-4094
Jon#
Jon#sh int port-chann 10 switchpor
Switchport: Enabled
Voice VLAN: none
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Hope this helps. I'm not sure where I went wrong on this set up. I also noticed that on the 3750, the 10.11.1.x ip address is on vlan 10, but on the new 3850, the 10.11.1.14 address is on vlan 1. Do I need to change that? Vlan 10 is used for my production systems, so I need to be careful with what changes I make there.
Many thanks for your help.
JD
JD,
     reliability 255/255, txload 1/255, rxload 0/255  >>>>>>>. Rxload 0- this is not good if you see this then the port-channel doesnt work.
     reliability 255/255, txload 1/255, rxload 255/255 >>>. Rxload 255
Next Action:
I appreciate if you could reboot both the boxes once.
Inayath
Thanks Inayath.
The 3750 (garfield) is my core production switch, so rebooting it is going to be a hard sell. Unless you mean reboot both 3850's boxes (the stack) only? Since the 3850 are new, they have nothing connected to them, and can be rebooted with no impact.
How about doing a shut \ noshut on all the interfaces? You think that might help? Or how about tearing down, deleting and recreating the port-channels?
JD
JD,
Okay lets try this:
2- Reboot the 3850.
Thank you. This is issue is resolved. I ended up recreating the port channel, and created layer 3 SVI for the switches, for each VLAN.
For anybody else who may run into this, here is a sample of what I did.
int Gi1/1/1
shut
switchport
switchport trunk allowed vlan ALL
switchport nonegotiate
channel-group 2 mode active
int port-channel 2
switchport trunk allowed vlan all
exit
Do the same on for all interfaces. Make sure your port channel numbers are the same and that your IP addresses are on the same vlan. I had my 10.11.1.x IP address on vlan 10 on switch, and the new switch IP of 10.11.1.xx was on vlan 1.
It all works now.
Thanks!
wow as expected.
can you please mark the thread as answered or solved rather than leaving it a unanswered.
