Trunk and active vlans. plus VTP configuration.
Alexey Shvarev
Hello All,
sorry for my english.
I have to swithces 4506(also as a router between switches) and 3750 connected by trunk. I wanted to replace 3750 with 3750G model. so i coppyed config from old one to new and cheked the port's names and configuration to be currect. So after sturtup it doesnt work curectly. i don't know why but command show interfaces port-channel 1 trunk  returns me this result for the new switch.
Port        Mode             Encapsulation  Status        Native vlan
Po1         on               802.1q         trunking      254
Port        Vlans allowed on trunk
Po1                 3,112,144-145,160-161,176-177,192-193,208-209,216-217,224-225,243,247,253-254
Port                Vlans allowed and active in management domain
Po1                 161
Port                Vlans in spanning tree forwarding state and not pruned
Po1                 161
i don't undestand why only one VLAN allowed and active. the old 3750 works fine. all allowed vlans are active on old one. Plroblem is that 161 is a access VLAN configured on almost all ports on 3750 switch, also there is voice vlan on all ports - 177. But i can't see it as active. What I have after power on new switch - phones are started, and even recived IP by DHCP (ip helper configured for all vlans on 4506 switch - it is also router between VLANs), but i can't see or ping any other vlans from it. i can see whole netwotk only from 161 VLAN. so phones are not registered.
the same command for 4506 returns this: (and the same result for old 3750 with only one differance in a last line)
What i'm doing wrong? please advise!
thsnks
Alexey.
sorry again for my English, i'm new here.
Po1                 161,177,254
for old 3750
this is VTP stutus new 3750G
VTP Version capable             : 1 to 3
VTP version running             : 2
VTP Domain Name                 : Core_Moscow_Office
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Enabled
Device ID                       : 0024.f97e.0300
Configuration last modified by 10.102.255.129 at 3-1-93 00:32:15
Local updater ID is 10.102.255.129 on interface Lo100 (first layer3 interface fo
und)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 6
Configuration Revision            : 0
MD5 digest                        : 0x3F 0xEC 0xE2 0xEF 0x30 0xA9 0x74 0x41
                                    0xCA 0x8A 0xC9 0x88 0x9F 0x3B 0x63 0xF5
this is for 4506
VTP Version                     : running VTP2
Configuration Revision          : 33
Number of existing VLANs        : 28
VTP Pruning Mode                : Enabled
VTP V2 Mode                     : Enabled
MD5 digest                      : 0x67 0x37 0x8C 0xFD 0x0D 0x5B 0x16 0x2A
Configuration last modified by 10.102.128.254 at 9-25-08 23:30:10
Local updater ID is 10.102.128.254 on interface Vl3 (lowest numbered VLAN interface found)
glen.grant
   The port channel trunk is not working correctly , thus vtp is not propagating the vlan information the way it should.  To help you will probably have to post the port channel configuration from both sides along with the port setup in the port channel . A show vtp status would help.  That is one of th issues when forcing on a portchannel or trunk , as long as you  have a physical link it will show the links as trunking when they might not be .   Verify each side matches exactly on each side for the port channel SVI ,  port settings in the channel, and the trunk parameters .  Also check to see if there is any vtp password being used , if so that also has to match .  Does the new 3750 have to be a server or can it be a client .  You should have 2 servers in any vtp setup but the rest should be clients...
Hi, thanks for quick replay.
The problem is that it is working on old 3750. As I told I've coppyed config one to one to the new 3750G, only changed interfaces from FE to GE. And it is not working on new...
So, it looks from main switch-router 4506 everything fine. At least should be.
configs for PChannel and interfaces below.
I have a question, is VTP configuration keeped in config file or not? i couldn't find any configuration for VTP (client or server, or any, only domain name. also no password for VTP domain used)
Unfourtunataly I had to rollback all changes, so all commands for 4506 have run on working infrustructure - 4506+old3750.
also vtp status commands looks different on old and new 3750. Probably HW or IOS differance.
let me know if I need to grab anything else.
port channal and interfacees config for 4506:
interface Port-channel1
switchport
switchport trunk native vlan 254
switchport trunk allowed vlan 3,112,144,145,160,161,176,177,192,193,208,209
switchport trunk allowed vlan add 216,217,224,225,243,247,253,254
switchport mode trunk
logging event link-status
logging event trunk-status
qos trust cos
interface GigabitEthernet1/1
qos trust cos
channel-group 1 mode desirable
interface GigabitEthernet1/2
qos trust cos
4506#show interfaces port-channel 1
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0011.21f9.fc81 (bia 0011.21f9.fc81)
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is N/A
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi1/1 Gi1/2
  Last input 00:00:05, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 828000 bits/sec, 127 packets/sec
  5 minute output rate 1401000 bits/sec, 153 packets/sec
     9053409266 packets input, 4616939860262 bytes, 0 no buffer
     Received 10228476 broadcasts (6717593 multicasts)
     12573430094 packets output, 15121841480153 bytes, 0 underruns
     0 lost carrier, 0 no carrier
for new 3750G (and old as well)
logging event bundle-status
logging event spanning-tree
logging event status
interface GigabitEthernet1/0/49
mls qos trust cos
interface GigabitEthernet1/0/50
mls qos trust cos
#show vtp status
Configuration last modified by 10.10.5.9 at 3-1-93 00:32:15
Local updater ID is 10.10.5.9 on interface Lo100 (first layer3 interface fo
und)
Feature VLAN:
   Did the etherchannel come up correctly when you tried to bring it up ? As you are trying to negotiate the port channel  you could verify with "show etherchannel summory or show etherchannel detail to see if it aggregated the ports correctly. When bringing up the port channel make sure to bring up both ports at the same time , don't try to bring up one at a time , this sometimes leads to unpredictable results.  If it did not it will usually give you an indication in the logs themselves why it did not bundle them.  The vtp information will not show up when the switch is in server or client mode , it does show up if you run the connections in transparent mode .  VTP info is stored in the vlan.dat file. I see vtp pruning is off on the 3750 side and on for 4506 , not sure if this makes any difference or not . Other than that I do not see anything really that jumps out that is incorrect in your config . I normally run "channel-group X mode desirable non-silent" between cisco boxes but the way you have it should work fine also.
