trunk between asa 5510 and aironet 1142 (standolone)
Hi!
Connection schema is: asa5510 --> cisco switch SG200 --> 1142 aironet (standalone)
I did trunk port between devices
vlan 1 (on firewall is Etherenet 0/1)
vlan 100 (on firewall is Etherenet 0/3.100)
vlan 200(on firewall is Etherenet 0/3.200)
and vlans working, i have internet and i can reach company lan, but i can't reach bvi1 port for management!!
because bvi1 interface using untaged packets.
So how to solve that problem, make reachable bvi1 interface from lan?
Antonio Knox
Level 7
Level 7
Assign the BVI an address on the native vlan of the trunk between the ASA and 1142.  That traffic would then traverse the trunk untagged by default and should work.
i changed bvi1 IP to native vlan ip, but no luck
Solved!!!
on switch was 1vlan taged, i did untag 1vlan packets
If my post was helpful, please rate.  Thanks, and glad your issue was resolved.
