Trunk between Cisco an Aruba
mulbreizh
Hello and sorry for my bad english,
I have a lag/etherchannel between my Cisco C3850 and two Aruba 8100 in stack. I have troubles because there is a lot of packets discarded as you can see below on picture.
My configuration on Cisco is like this :
interface Port-channel32
description aruba
switchport trunk native vlan 999
switchport mode trunk
switchport nonegotiate
interface TenGigabitEthernet1/0/39
description Aruba A8100
channel-group 32 mode active
interface TenGigabitEthernet1/0/40
and on Aruba :
interface lag 1 multi-chassis
description LACP-to-Coeur
no shutdown
no routing
vlan trunk native 999
vlan trunk allowed 1-2,5,15,17,21-22,25-26,45,51,54,56,61-62,70,89,100,102,104,110,999
lacp mode active
spanning-tree bpdu-filter
spanning-tree rpvst-filter
interface 1/1/47
description aggr LAG1 to core
no shutdown
lag 1
interface 1/1/48
no shutdown
lag 1
do you think this configuration is bad ?
61 Replies 61
share
show interface PO <<- Port channel connect cisco to aruba
MHM
C3850#show int po 32
Port-channel32 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 8024.8f7c.8528 (bia 8024.8f7c.8528)
Description: aruba salle E011
MTU 1500 bytes, BW 40000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 3/255, rxload 3/255
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is N/A
input flow-control is on, output flow-control is unsupported
Members in this channel: Te1/0/39 Te1/0/40 Te2/0/37 Te2/0/38
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 10w0d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 32212049
77
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 520479000 bits/sec, 48487 packets/sec
5 minute output rate 618248000 bits/sec, 57664 packets/sec
224933561996 packets input, 298435325573539 bytes, 1 no buffer
Received 73389426 broadcasts (58444006 multicasts)
0 watchdog, 58444006 multicast, 0 pause input
121916216788 packets output, 136144030059965 bytes, 0 underruns
Output 209866243 broadcasts (0 multicasts)
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
qos queue-softmax-multiplier 1200
Add this in Cisco SW and monitor the output drop
MHM
this command has impact for production ? i apply only in interface ?
For information, from side of Cisco i have spanning-tree Rapid-PVST and from Aruba MSTP
It dont matter' the Aruba use bpdu filter so any stp not exchange between two link.
And STP is make UP or down not make interface UP but some data is drop.
You have queue issue only
MHM
Often, but not always, it has a positive impact, but a negative impact is a possibility.  The latter, a possible reason why it's NOT the Cisco default although Cisco suggests trying it.
Whenever you make QoS configuration changes, and/or resource configuration changes, you want to carefully monitor "before" vs. "after" for some time (usually up to a week).
Hello
and on Aruba :
Mstp is per instance stp NOT per vlan like RPVST, so really you should not be pruning on the aruba Mlag
aruba
sh spanning-tree summary root
sh lacp aggregates
sh int x/x/x (physical interfaces for lag)
sh int lag 1
cisco
sh spanning-tree root
sh etherchannel 32 summary | be Gr
sh int port 32
sh int x/x (physical interfaces for PC)
Kind Regards
Paul
What ever Aruba use he use stp or mst he already disable send bpdu by bpdufilter so cisco SW dont see it as SW but as Host use trunk.
I explain this in his other post.
@mulbreizh you STP is OK if ypu have one link' the data is drop becuase of small queue I send to you link check it and apply  command I recommend
MHM
I have past the command but still have troubles on interface /
run command
wait 10 min then run command again
MHM
reliability 255/255, txload 2/255, rxload 9/255
Last clearing of "show interface" counters 2d18h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 83366093
5 minute input rate 1534175000 bits/sec, 135225 packets/sec
5 minute output rate 352239000 bits/sec, 41753 packets/sec
19102727012 packets input, 27188562606598 bytes, 0 no buffer
Received 4224733 broadcasts (2501193 multicasts)
0 watchdog, 2501193 multicast, 0 pause input
10021365963 packets output, 12916592083168 bytes, 0 underruns
Output 6257767 broadcasts (0 multicasts)
reliability 255/255, txload 2/255, rxload 6/255
5 minute input rate 1000718000 bits/sec, 90584 packets/sec
5 minute output rate 349594000 bits/sec, 39257 packets/sec
19151585292 packets input, 27255565007793 bytes, 0 no buffer
Received 4241643 broadcasts (2507321 multicasts)
0 watchdog, 2507321 multicast, 0 pause input
10044193620 packets output, 12942221695970 bytes, 0 underruns
Output 6295692 broadcasts (0 multicasts)
There is no more output drop
83366093
83366093
