Trunk between Cisco Catalyst and DLINK DES-7210
r-klein
i would like to configure a Trunk with all VLANs between a Cisco Catalyst 3650 an a DLINK DES-7210.
On the DLINK is the def. GW via VRRP defined.
Now i get the following Error:
%ARP-4-DUPADDR: Duplicate address 172.28.72.1 on interface VLAN 72 port TenGigabitEthernet 5/3, sourced by 24e9.b397.2c34
This is the Uplink Interface on the Cisco Switch.
What can cause this?
here`s the config of the Cisco Port:
interface TenGigabitEthernet1/1/4
switchport mode trunk
switchport nonegotiate
load-interval 30
udld port disable
spanning-tree bpdufilter enable
end
sh inter trunk
Port        Mode             Encapsulation  Status        Native vlan
Te1/1/4     on               802.1q         trunking      1
Port        Vlans allowed on trunk
Te1/1/4     1-4094
Port        Vlans allowed and active in management domain
Te1/1/4     1,8,12,16,20-24,32,36,40,44,48,56,64,68,72,76,80,88,92,96,201,211,239-242,244-249,260,264,268,1212,1216,1220,1224,1228,1232,1234,1236,1240,1244,1248,1252,1256,1260,1264,1268
Port        Vlans in spanning tree forwarding state and not pruned
and here is the DLINK Switch:
interface TenGigabitEthernet 5/3
description test
sh int ten 5/3 trunk
Interface                Mode   Native VLAN VLAN lists
TenGigabitEthernet 5/3   On     1           ALL
Jon Marshall
Do you have the same IP configured on both switches ?
Jon
