03-09-2022 05:19 AM
Good morning all
I would like to configure two ports of two switches in trunk mode so that the two cables can carry each of the packets because sometimes I do it but I realize that there is only one cable carrying it.
Solved! Go to Solution.
03-09-2022 05:39 AM
that will be no problem, the necessary commands are (may vary depending on switch model and IOS version):
interface GigabitEthernet1/0/4
switchport mode trunk
channel-group 1 mode active
interface GigabitEthernet3/0/4
interface Port-channel1
from here on you make most changes using the virtual interface Port-channel-1,
not on each separate physical interface
03-09-2022 11:32 PM
Hello Mr Pieterh
Thank you very much and have peace.
03-09-2022 05:25 AM
If they are individual truk one of the port go blocking mode due tp spanning tree, if you like to use both the links, then configure port-channel (is this make sense ?)
even if you configure port-channel traffic use only 1 - but they use distributed load.
03-09-2022 05:39 AM
03-09-2022 11:32 PM
Hello Mr Pieterh
