trunk not working
lformelli
Level 4
Level 4
I have an a simple configuration between two switches.
An 2950 with IOS 12.1(20)EA1a connected in trunk to an 2960 with IOS 12.2(25r)SEE1.
I have configured the same vtp domain name, I see from command "sh int status"
that both port link are in trunk but the vlans don't pass from a switch to the other excluded native vlan (1).
What can be ?
best regards
Lorenzo
2 Accepted Solutions
Lorenzo,
Its good to know that the problem is resolved. I am gald to help you. Please continue your participation in the netpro forum.
** Note, Please use the rating system to rate all the helpful posts and appreciate our efforts that we all our putting in our busy schedules.
-amit singh
Thanks Jon for appreciating the post. Yeah agree with you.. we get a lot to learn daily..
Lets keep up our spirits high...
-amit singh
12 Replies 12
Jon Marshall
Hi Lorenzo
Is one of the switches a VTP server and one a vtp client. Are you saying that if you add a vlan to one of your switches it doesn't get propogated to the other.
Not clear what you mean about the native vlan.
Could you post output of sh vtp status and elaborate on your problem.
Jon
Hi Jon,
are both VTP server however I attach
both VTP status:
for 2950:
sw2-Bolo#sh vtp status
VTP Version : 2
Configuration Revision : 204
Maximum VLANs supported locally : 250
Number of existing VLANs : 7
VTP Operating Mode : Server
VTP Domain Name : racka
VTP Pruning Mode : Enabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x71 0x16 0xA6 0xE7 0x70 0xC9 0xBB 0xB1
Configuration last modified by 192.168.10.201 at 9-11-95 22:10:58
Local updater ID is 192.168.10.202 on interface Vl1 (lowest numbered VLAN interf
ace found)
for 2960:
sw7-bolo#sh vtp sta
VTP Version : 2
Configuration Revision : 7
Maximum VLANs supported locally : 255
Number of existing VLANs : 5
MD5 digest : 0xBC 0x08 0x63 0xCF 0x44 0x58 0x11 0x32
Configuration last modified by 192.168.10.207 at 3-14-93 04:34:44
Local updater ID is 192.168.10.207 on interface Vl1 (lowest numbered VLAN interf
ace found)
Please paste show VTP counters from both the switches.
Hi asingh 2
here is:
from 2950 :
sw2-Bolo#sh vtp counters
VTP statistics:
Summary advertisements received : 263629
Subset advertisements received : 126
Request advertisements received : 617
Summary advertisements transmitted : 267977
Subset advertisements transmitted : 719
Request advertisements transmitted : 0
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 0
from 2960 :
sw7-bolo#sh vtp counters
VTP statistics:
Summary advertisements received : 4686
Subset advertisements received : 2361
Request advertisements received : 0
Summary advertisements transmitted : 899
Subset advertisements transmitted : 8
Request advertisements transmitted : 2326
Number of config digest errors : 2361
Urfan Khaliq
Level 3
Level 3
Hi Lorenzo,
Is the trunking set to the same (.1q or isl) on both switches?
Also it would help if you could attatch the configs?
Urfan
yes are both configured on 802.1q
I attach config for both port:
2950:
sw2-Bolo#sh int fa 0/23 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
2960:
sw7-bolo#sh int fa 0/23 sw
Switchport: Enabled
Administrative Mode: dynamic auto
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
You have a VTP password mismatch on 2960 switch.
Check this:
from 2960 :
VTP statistics:
Number of config digest errors : 2361 ---> See here
Please make sure that you have the same VTP password at both the ends. Change the password and you should be good to go.
HTH,Please rate all the posts that have helped.
-amit singh
Hi amit,
I had differently password.
Now I have seen insert the same password
for both and all working fine.
Best regards
Lorenzo
Lorenzo,
-amit singh
Hi Amit
That's the beauty of doing NetPro :). Never knew this was how to tell a password mismatch.
Deserves 5 points.
Jon
-amit singh
fsoffia
Level 3
Level 3
hi Lorenzo,
I want to ask you something about 802.1q trunk on cat2960.
It seems me that cat2960 TAGs the NATIVE VLAN (default 1) in trunk links ("Administrative Native VLAN tagging: enabled").
Standard 802.1q does not want native vlan tagging !!!
Switch#sh interfaces f0/1 switchport
Switchport: Enabled
Voice VLAN: none
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switch#
This vlan1 tag in 802.1q trunk is a problem when I try using a cisco2610 to do INTERVLAN routing.
The cisco2610 does not tag native vlan, so there is a mismath !
Do you know if is there a way to UNTAG the NATIVE VLAN on cat2960 ?
thanks
francesco
