Trunk port going up and down...
cre8toruk
Hi all,
I've noticed the below on our core switch to edge switch connection since forever really... I'm wondering if it's some sort of load balancing or if it indicates a problem ?
The Core is a pair of stacked SG350XG-2F10's and the edge is a stack of 4 SG350X-48's.
I have a cable in 10Gbe uplinks connected to SW1 and SW4 in the edge stack which then connect to te1/0/1 and te2/0/1 on the core.
Can anyone shed any light ?
2147417691 2021-Aug-25 08:00:19 Informational %TRUNK-I-PORTADDED: Port te1/0/1 added to Po3
2147417692 2021-Aug-25 08:00:16 Informational %LINK-I-Up: te1/0/1
2147417693 2021-Aug-25 07:31:56 Warning %LINK-W-Down: te1/0/1
2147417694 2021-Aug-25 07:31:56 Informational %LINK-I-Up: te1/0/1
2147417695 2021-Aug-25 07:02:53 Warning %LINK-W-Down: te1/0/1
2147417696 2021-Aug-25 07:02:53 Informational %LINK-I-Up: te1/0/1
2147417697 2021-Aug-25 06:58:17 Warning %LINK-W-Down: te1/0/1
2147417698 2021-Aug-25 06:58:17 Warning %TRUNK-W-PORTREMOVED: Port te1/0/1 removed from Po3
2147417699 2021-Aug-25 06:58:09 Informational %TRUNK-I-PORTADDED: Port te1/0/1 added to Po3
2147417700 2021-Aug-25 06:58:06 Informational %LINK-I-Up: te1/0/1
2147417701 2021-Aug-25 05:36:10 Warning %LINK-W-Down: te1/0/1
2147417702 2021-Aug-25 05:36:10 Informational %LINK-I-Up: te1/0/1
2147417703 2021-Aug-25 04:01:36 Warning %LINK-W-Down: te1/0/1
2147417704 2021-Aug-25 04:01:36 Informational %LINK-I-Up: te1/0/1
2147417705 2021-Aug-25 03:49:39 Warning %LINK-W-Down: te1/0/1
2147417706 2021-Aug-25 03:49:39 Informational %LINK-I-Up: te1/0/1
2147417707 2021-Aug-25 03:45:35 Warning %LINK-W-Down: te1/0/1
2147417708 2021-Aug-25 03:45:35 Warning %TRUNK-W-PORTREMOVED: Port te1/0/1 removed from Po3
2147417709 2021-Aug-25 00:46:23 Informational %TRUNK-I-PORTADDED: Port te1/0/1 added to Po3
2147417710 2021-Aug-25 00:46:20 Informational %LINK-I-Up: te1/0/1
2147417711 2021-Aug-25 00:35:18 Warning %LINK-W-Down: te1/0/1
2147417712 2021-Aug-25 00:35:18 Warning %TRUNK-W-PORTREMOVED: Port te1/0/1 removed from Po3
2147417713 2021-Aug-25 00:19:43 Informational %TRUNK-I-PORTADDED: Port te1/0/1 added to Po3
2147417714 2021-Aug-25 00:19:40 Informational %LINK-I-Up: te1/0/1
2147417715 2021-Aug-24 23:52:20 Warning %LINK-W-Down: te1/0/1
2147417716 2021-Aug-24 23:52:20 Warning %TRUNK-W-PORTREMOVED: Port te1/0/1 removed from Po3
2147417717 2021-Aug-24 23:51:59 Informational %TRUNK-I-PORTADDED: Port te1/0/1 added to Po3
2147417718 2021-Aug-24 23:51:56 Informational %LINK-I-Up: te1/0/1
2147417719 2021-Aug-24 23:29:26 Warning %LINK-W-Down: te1/0/1
2147417720 2021-Aug-24 23:29:26 Informational %LINK-I-Up: te1/0/1
2147417721 2021-Aug-24 22:49:37 Warning %LINK-W-Down: te1/0/1
2147417722 2021-Aug-24 22:49:37 Informational %LINK-I-Up: te1/0/1
2147417723 2021-Aug-24 22:28:16 Warning %LINK-W-Down: te1/0/1
2147417724 2021-Aug-24 22:28:16 Informational %LINK-I-Up: te1/0/1
2147417725 2021-Aug-24 22:15:59 Warning %LINK-W-Down: te1/0/1
2147417726 2021-Aug-24 22:15:59 Warning %TRUNK-W-PORTREMOVED: Port te1/0/1 removed from Po3
2147417727 2021-Aug-24 18:58:07 Informational %TRUNK-I-PORTADDED: Port te1/0/1 added to Po3
2147417728 2021-Aug-24 18:58:04 Informational %LINK-I-Up: te1/0/1
2147417729 2021-Aug-24 18:52:19 Warning %LINK-W-Down: te1/0/1
2147417730 2021-Aug-24 18:52:18 Informational %LINK-I-Up: te1/0/1
2147417731 2021-Aug-24 18:48:16 Warning %LINK-W-Down: te1/0/1
2147417732 2021-Aug-24 18:48:16 Warning %TRUNK-W-PORTREMOVED: Port te1/0/1 removed from Po3
2147417733 2021-Aug-24 11:50:45 Informational %TRUNK-I-PORTADDED: Port te1/0/1 added to Po3
2147417734 2021-Aug-24 11:50:42 Informational %LINK-I-Up: te1/0/1
2147417735 2021-Aug-24 11:24:20 Warning %LINK-W-Down: te1/0/1
5 Replies 5
marce1000
 - It could be a physical link (layer) problem,. check logs at the other end too, also look at port-counters , at both ends.
 M.
check error disable by
show interface status,
do this when the interface down.
Giuseppe Larosa
Hello @cre8toruk ,
check the signal level (power) on the fiber link on both ends.
There may be too much attenuation and one receiver has the received power near the lowest valid value.
One of the following commands should work
show interface te1/0/1 transceiver detail
or
show controller ten1/0/1 detail
see the power levels on both ends
also the show interface te1/0/1 should show an high rate of input errors CRC or other type.
Hope to help
Giuseppe
Hi Giuseppe,
thanks but the connections are copper.
kr
Paul.
Hello
@cre8toruk wrote:
Hi Giuseppe,
kr
Paul.
How far is the length of the switch interconnection on this copper?
When applicable perfrom a TDR test and post the results:
test cable tdr interface X/X  - (note perfroming test is disruptive to the link)
Kind Regards
Paul
