Trunk Question and VLAN question (CatOS vs IOS).
anthonysgroi
First I want to say thank you for any help, here it goes. I have two 6509's running CatOS and we are bringing online a new 6509 running IOS and im not sure on a few things and the config conversion tool isnt to great. First the trunk....
This is the CatOS side.
set trunk 1/1 on dot1q 1-1005,1025-4094
set spantree portfast 1/1 disable
Now is this correct for the IOS side?
(on the correct interface of course)
switchport mode trunk
And the other part of my question is all our other switch's run CatOS so our VLAN configuration is like so.
#vtp
set vtp domain iha
set vtp mode client vlan
set vtp passwd dlt
My understanding that this pulls all the info from our cores for the VLANs now how do we do this in IOS?
And lastly in CatOS you IP the switch using this command.
set interface sc0 10 10.10.10.139/255.255.255.0 10.10.10.255
Is there an equivalent command for IOS? Thanks again.
glen.grant
The cores must be set as the servers if they are pulling vlan info from there . Myself I would manually prune any vlans not needed off the trunks .
IOS side
IOS trunk
switchport trunk encap dot1q
switchport trunk native vlan X (must match the native of the uplink).
vtp domain iha
vtp mode client
vtp password xxx
addressing
IOS
int vlan 10
ip address 10.10.10.X 255.255.255.0
no shut
How you handle the default gateway depends if you turned off ip routing on the new 6500's , if so then use the ip default gateway command , if routing is still turned on then use a default static route 0.0.0.0 0.0.0.0 .
Hey thanks alot.
