Trunking and telnet problem
macboy276
Level 3
Level 3
Hi Everybody,
I have pasted the whole configuration of my cisco 3760 switch.
I have two issues.
1. I cannot telnet to this switch.
2. on ethernet port 1/0/1 i have configured switch mode trunk. i am not getting ip address on this port other wise i am getting ip where ever access mode is configure. i need to configure port 1 trunked.
Am i missing any command or config. Any help would be helpful
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service sequence-numbers
hostname ABCD2013SW01
logging buffered 64000 debugging
no logging console
enable secret 5 ----------------------
enable password 7 -------------------
username badmin privilege 15 secret 5 $1$3xoh$Hpp2jaldsfjladsfj
username muadminas privilege 15 secret 5 $1$YJb6$sCdareljlkje9ff
aaa new-model
aaa authentication login CON local
aaa authentication login VTY local
aaa authentication enable default enable
aaa authorization exec default local
aaa session-id common
clock timezone CET -5
clock summer-time EDT recurring
switch 1 provision ws-c3750g-24ts-1u
vtp mode transparent
ip subnet-zero
no ip source-route
ip routing
ip icmp rate-limit unreachable 1000
ip domain-name xxxxxx.xxx
ip name-server 192.168.1.2
ip name-server 192.168.1.3
ip dhcp-server 192.168.1.3
no file verify auto
spanning-tree mode pvst
--More--         !
vlan internal allocation policy ascending
vlan 2
name inside
vlan 8
name Internal_LAN
interface Null0
no ip unreachables
interface GigabitEthernet1/0/1
description **LAN**
switchport trunk allowed vlan 1-10
switchport mode trunk
no logging event link-status
spanning-tree portfast
interface GigabitEthernet1/0/2
description *** User Port ***
switchport access vlan 2
switchport mode access
interface GigabitEthernet1/0/3
switchport access vlan 8
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
--More--         !
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
  description **UPLINK**
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
no ip redirects
ip directed-broadcast
no ip proxy-arp
shutdown
interface Vlan2
description ** Management **
ip address 192.168.1.92 255.255.255.0
no ip redirects
no ip proxy-arp
interface Vlan8
description ** Internal_LAN **
ip address 172.168.1.92 255.255.255.0
ip helper-address 192.168.1.3
no ip redirects
no ip proxy-arp
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http authentication local
access-list 97 remark ** NTP-ACCESS **
access-list 97 remark ** NTP-Server
access-list 97 permit 192.168.1.3
access-list 97 deny   any log
access-list 98 remark ** SNMP-ny   any log
access-list 98 remark ** SNMP-ACCESS  **
access-list 98 permit 192.168.1.60
access-list 98 deny   any log
access-list 99 remark ** VTY_ACCESS **
access-list 99 deny   any log
access-list 99 permit 192.168.1.0 0.0.0.255
snmp-server community abiYHORHAEN RO
snmp-server chassis-id ABCD2013SW01
radius-server source-ports 1645-1646
control-plane
banner exec ^CCCCCCCCC
    VMWAFAR TECHNOLOGY
you are now connected to: $(hostname).$(domain)
^C
banner login ^CCCCCCCCC
**      banner                                                    **
**********************WARNING***************************************
*secure                                                            *
^C
line con 0
exec-timeout 30 0
login authentication CON
history size 30
transport output none
stopbits 1
line vty 0 4
access-class 99 in
exec-timeout 30 0
password 7 091D5EADKRCR130700
logging synchronous
login authentication VTY
length 0
history size 30
transport preferred none
line vty 5 15
access-class 99 in
exec-timeout 30 0
password 7 091D5E080138934450
logging synchronous
length 0
history size 30
ntp clock-period 36028917
ntp access-group peer 97
ntp server 192.168.1.7 prefer
end
certifiedrawi37
Frequent Visitor
Frequent Visitor
you need to rewrite access-list 99
or delete it and rewrite it back
it should be
try to add
switchport trunk native vlan vlan_ID
where vlan_ID is either 2 or 8
Thanks, with the help of your suggestion the problem no 1 is solved and I can telnet now. The second problem is partially solved, now i can get Dynamic ip from vlan 2 with the suggested configuration. I can get through with VLAN 8 either way dynamic or static.
