Trunking between 3550 and 2960 switch
M Talha
Dear All,
i have problem related to trunking between my distribution switch and access layer switch. i formed a trunk on
my cisco 3550
interface GigabitEthernet0/5
switchport mode trunk
and on my 2960 as
interfaces gigabitEthernet 0/1
but still not been able to connect between two switches, the port status for both switches are here
Switch#sh interfaces gigabitEthernet 0/1
GigabitEthernet0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 20bb.c0b0.0d19 (bia 20bb.c0b0.0d19)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Switch#sh interfaces gigabitEthernet 0/5
GigabitEthernet0/5 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0012.7ff0.1b05 (bia 0012.7ff0.1b05)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is SX
input flow-control is off, output flow-control is off
Received 0 broadcasts (0 multicast)
what could be reason !!!!! does this have any configuration issues. my doubt is still on the physical media between these ?? still searching for answers
Leo Laohoo
If you default both ports, does the link go up?  I am suspecting NO.
The link is fibre optic.  I'm suspecting you've got a Layer 1 issue.
Leo Laohoo
