trunking: switchport nonegotiate
Wassim Aouadi
Level 4
Level 4
I read that in order to disable sending DTP frames, we issue "switchport nonegotiate".
But, why do we need it if we already specified that the port is in access or tunk mode already? setting a port to access or trunk disables trunk negotiation, doesn't it?
Forum Tips: 1. Paste images inline - don't attach. 2. If you find my post helpful, please give it a thumbs up or mark it as a correct solution; You never know in the future who you might help doing so..
Peter Paluch
Hi Wassim,
A port statically set to trunk mode still sends DTP packets to inform the other side to also activate the trunk mode. Only a port set to access mode does not send DTP packets.
Best regards,
Peter
5 Replies 5
Peter Paluch
Hi Wassim,
Best regards,
Peter
Peter
Now you've got me confused -
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cd45326/0#selected_message
ie. my understanding is non-negotiate stops the port sending DTP frames which is what you put in your previous thread but not this one.
Please help me out :-)
Jon
Hi Jon,
I am sorry if I confused you. Still, I am not sure in what way I have created a confusion. Can you be more specific?
Hoping to read from you soon.
Best regards,
Peter
Peter
"Only a port set to access mode does not send DTP packets."
A port set to trunk mode ie. "switchport mode trunk" and then set to nonegotiate as well does not send DTP frames.
Jon
Hi Jon,
Oh, yes, that is correct. I was merely replying to the original post context where Wassim asked: "setting a port to access or trunk disables trunk negotiation, doesn't it?" - and I answered only within context of this question. It is true that my answer here is not as exhaustive as my earlier post you have indicated.
Sorry once again for creating confusion, and thanks very much indeed for pointing it up!
Best regards,
Peter
