Trunking with Ether Channel
Wajih Rehman
I have two switches with 4 links connecting together. I could see all the links are trunking and STP block the redundant path. Then I setup ether channel between them.
From Switch-2:
IOU2#show etherchannel summary
Flags:  D - down        P - bundled in port-channel
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
21     Po21(SU)        PAgP      Et0/0(P)    Et0/1(P)    Et0/2(P)
                                 Et0/3(P)
From Switch-1:
IOU1#show etherchannel summary
12     Po12(SU)        PAgP      Et0/0(P)    Et0/1(P)    Et0/2(P)
                                 Et0/3(P)
What I was expecting that when I will display interfaces with trunk , I should see these two in their switches. However, the output does not show them.
From Switch-1:
IOU1#show int trunk
IOU1#
IOU1#
From Switch-2:
IOU2#show interfaces trunk
Port        Mode             Encapsulation  Status        Native vlan
Et3/2       desirable        n-802.1q       trunking      1
Et3/3       desirable        n-802.1q       trunking      1
Port        Vlans allowed on trunk
Et3/2       1-4094
Et3/3       1-4094
Port        Vlans allowed and active in management domain
Et3/2       1,10-11
Et3/3       1,10-11
Port        Vlans in spanning tree forwarding state and not pruned
Et3/2       10-11
Et3/3       11
IOU2#
Is there anything else I need to do?    Thanks for your help
Wajih
InayathUlla Sharieff
By default DTP is disabled on most of the switches.
Either enable the DTP or confiugre the port to be in the trunk.
int x/x
switchport mode desirable  or
switchport mode trunk
5 Replies 5
Did you configure the port-channel interfaces as "switchport mode trunk"
Madhu
Thanks Madhu and Inyatullah. The problem was missing switchport mode trunk command in the interface.
One more question, do we need to define trunk on port-channel as well or interface is enough?
The best practice for port-channeling is you add member ports to port-channel by the channel-group command and all other configuration should go under port-channel.
So basically when you say under port-channel "switchport mode trunk", it goes to member ports automatically.
Madhu
Just like to add what Madhu said,,,
Always do the configuration on the port channel and not on the physical interfaces.... As u know that the physical interfaces part of port channel will inherit the configuration. Were as if u do the configuration on the interface the same will not be copied back to port channel.
Hth
Inayath
int x/x
