Trunking
navneet_78
I have configured 3 VLANs on my switch. I want to configure the interfaces on the router to accomodate the trunking information i just made. There is no Etherchannel on my switch since i have a stack. switch is doing dot1q trunking
How do i do that?
Appreciate your response.
Navneet
3 Accepted Solutions
ankbhasi
Hi Navneet,
I believe you are talking on inter vlan routing with router on stick model.
You need to create sub-interfaces on your router port to which your switch port is connected and then configure encapsulation under all subinterfaces.
Something like this
interface fa0/0.1
encapsulation dot1q
ip adddress
interface fa0/0.2
encapsulation dot1q
ip adddress
Now for any subinterface to support encapsulation command it is necessary that your router IOS is having a minimum of IP PLUS feature set.
Ankur
*Pls rate all helpfull post
Hi Navneet,
Just to add to Ankur's Post, try configuring the " native " vlan keyword under the respective vlan sub-interface which is a native vlan on the switch. By defualt Vlan 1 is Native vlan on the cisco switch. So whenever you are configuring the sub-interface for vlan1 on your router use "Native" keyword with that.Otherwise the things will not work. For example
nterface fa0/0.1
encapsulation dot1q 1 native
ip adddress a.a.a.a c.c.c.0
Check the link posted by the first poster, that link will really help you.
HTH,Please rate if it does.
-amit singh
6 Replies 6
jolmo
Level 4
Level 4
Thnx for the Link Jolmo. It really helped.
Cheers
Navneet
ankbhasi
Hi Navneet,
Something like this
interface fa0/0.1
encapsulation dot1q
ip adddress
interface fa0/0.2
encapsulation dot1q
ip adddress
Ankur
Hi Ankur,
Thanks a Lot.I was looking for the exact answer. I knew the config when etherchannel is configured on a switch.But this basic thing confused me..:))
Thanks Buddy
Cheers
Navneet
Hi Navneet,
nterface fa0/0.1
-amit singh
Yes i got the point.
Thnx Amit
Navneet
