Trying to connect a FritzBox 5530 to a Nexus 3064-X
HenriSan
I am trying to connect a FritzBox 5530 AON to a Nexus 3064-X, however the port doesn't come UP. I already tried this setup with different switches (Nexus 3172PQ-XL and Nexus N9K-C92160YC-X) and in those cases the link is established. Also tried to connect the Nexus 3064-X to a measuring device (EXFO EX1) and even there, the link is established. The Nexus 3064-X was also connected to another Nexus 3064-X and this also works with the SFPs I used.
Is there something that I am missing on why the FritzBox won't connect with the Nexus 3064-X ?
Versions:
Nexus --> NXOS 7.0(3)I7(9)
FritzBox 5530 --> 7.50
Used SFPs:
Nexus :
FritzBox --> 1G SFP 1310/1550 10km (SFP-GE-BX) from FiberStore
Config of the port in which the FritzBox is connected to:
interface Ethernet1/36
no description
lacp port-priority 32768
lacp rate normal
lldp transmit
lldp receive
lldp dcbx version auto
no lldp tlv-set management-address :: ipv6
no lldp tlv-set management-address 0.0.0.0
no lldp tlv-set vlan
cdp enable
switchport
switchport mode trunk
no switchport monitor
no switchport dot1q ethertype
no switchport priority extend
switchport access vlan 1
switchport trunk native vlan 1
switchport trunk allow-multi-tag
no switchport vlan mapping enable
switchport trunk allowed vlan 1100
priority-flow-control mode auto
priority-flow-control watch-dog-interval off
spanning-tree port-priority 128
spanning-tree cost auto
spanning-tree link-type auto
spanning-tree port type normal
no spanning-tree bpduguard
no spanning-tree bpdufilter
flowcontrol receive off
flowcontrol send off
delay 1
snmp trap link-status
mtu 1500
link debounce time 100
no beacon
no link transmit reset-skip
link mac-up timer 0
link dfe adaptive-tuning
speed auto
duplex auto
fec auto
dfe-tuning-delay 100
no port-type fabric
negotiate auto
logging event port link-status default
logging event port trunk-status default
storm-control broadcast level 100.00
storm-control multicast level 100.00
storm-control unicast level 100.00
no storm-control action
bandwidth 10000000
no bandwidth inherit
load-interval counter 1 30
load-interval counter 2 300
no load-interval counter 3
no switchport block multicast
no switchport block unicast
no switchport mac-learn disable
no shutdown lan
no switchport autostate exclude
no shutdown
Let me know if further information is needed and thank you in advance for your suggestions !!
marce1000
   - At the nexus side ,  verify if  the used SFP model is supported for this Nexus 3064-X , according to https://tmgmatrix.cisco.com/
     Also try toggling speed auto/fixed at both ends to see if that can help.
     Try flipping fiber pair on  patch cord (connection)
     Check the logs on both devices  when the connection is attempted to see if there are any error messages that can provide clues on what could be causing the issue.
 M.
