Trying to delete old NAT entries
mneumann1219
I have a bunch of old NAT entries and I need to get rid of them. I've tried using the no commands and to no avail. I tried using the clear ip nat translation command and packet tracer kept saying incomplete command. So what should I do to delete them? Here's what it looks like:PAT.PNG
6 Replies 6
 This command is probably the output of show nat translation, right?
What you need to do is remove the ACL that matches with the traffic you wont  to translate anymore.
Would be easier to help if you share the configuration from the device.
I've already deleted all the associated ACLs.
Here is my show run:
hostname Europe
no ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX10171S75-
spanning-tree mode pvst
interface FastEthernet0/0
ip address 172.30.0.1 255.255.0.0
ip ospf 1 area 1
ip access-group 130 in
ip access-group 140 out
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/0
no ip address
clock rate 2000000
shutdown
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Serial0/2/0
no ip address
clock rate 2000000
shutdown
interface Serial0/2/1
ip address 172.35.0.1 255.255.255.252
ip ospf network point-to-point
ip ospf 1 area 3
ip nat outside
interface Serial0/3/0
ip address 172.7.0.2 255.255.255.252
ip ospf 1 area 1
ip nat outside
interface Serial0/3/1
ip address 172.8.0.1 255.255.255.252
ip ospf 1 area 1
ip nat outside
interface FastEthernet1/0
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
redistribute ospf 1 metric 1 1 1 1 1
network 172.7.0.0
network 172.8.0.0
network 172.30.0.0
network 172.35.0.0
router ospf 1
log-adjacency-changes
redistribute eigrp 1 subnets tag 1
network 172.7.0.0 0.0.0.255 area 1
network 172.8.0.0 0.0.0.255 area 1
network 172.35.0.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
access-list 130 permit tcp any host 172.30.1.2 eq www
access-list 130 permit tcp any host 172.30.1.1 eq pop3
access-list 130 permit tcp any host 172.30.1.1 eq smtp
access-list 130 permit ip any any
access-list 140 permit tcp any any
access-list 140 permit ip any any
line con 0
line aux 0
line vty 0 4
login
end
If you deleted the ACL already you can also remove this:
conf t
no ip nat inside
no ip nat outside
no ip nat outside
Just keep in mind that with this you will delete all NAT on this device
mneumann1219
Okay so my NAT entries finally wen away some how. I tried setting up a PAT configuration for my router however I can no longer see what my NAT entries are at all. Whenever I type "show ip nat translations" I get no output.
This is what the show run looks like now:
hostname Europe
no ip cef
no ipv6 cef
ip ospf 1 area 1
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
no ip address
clock rate 2000000
shutdown
no ip address
clock rate 2000000
shutdown
ip ospf 1 area 3
ip nat outside
ip ospf 1 area 1
ip nat outside
ip ospf 1 area 1
ip nat outside
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 172.7.0.0
network 172.8.0.0
network 172.30.0.0
network 172.35.0.0
router ospf 1
ip nat pool inside 50.50.50.80 50.50.50.80 netmask 255.255.255.0
ip nat inside source list 1 pool inside overload
ip classless
access-list 1 permit 172.30.0.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Dymanic PAT can remove or modify by
1- remove ip nat inside from egress interface
2- clear nat table
3- modify the NAT config
4- add again ip nat inside
Martin L
You are missing * sign at the end.  Use CLI context help in form of ?
R1#clear ip nat ?
translation Clear dynamic translation
R1#clear ip nat tr
R1#clear ip nat translation ?
* Deletes all dynamic translations
% Incomplete command.
R1#clear ip nat translation *
R1#
R1#
Regards, ML
**Please Rate All Helpful Responses **
