trying to disable telnet once and for all.
support.edm
Switch#sh run
Building configuration...
Current configuration : 2455 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
enable password xxx
username admin privilege 15 password 0 xxx
clock timezone mst -7
ip subnet-zero
ip domain-name co-locate
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
switchport access vlan 520
interface FastEthernet0/30
interface FastEthernet0/31
speed 100
duplex full
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
switchport access vlan 12
interface FastEthernet0/48
speed 10
duplex half
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan520
ip address 172.17.193.11 255.255.255.0
no ip route-cache
ip default-gateway 172.17.193.1
ip http server
line con 0
line vty 5 15
end
Switch#
I thought removing the telnet password from line vty 0 15 would do it but I am still able to telnet in. It ask me for username and pw...and then it goes straight to enable mode.
6 Replies 6
a.alekseev
Level 7
Level 7
xxx(config-line)#transport input ?
all All protocols
lapb-ta LAPB Terminal Adapter
mop DEC MOP Remote Console Protocol
none No protocols
pad X.3 PAD
rlogin Unix rlogin protocol
ssh TCP/IP SSH protocol
telnet TCP/IP Telnet protocol
udptn UDPTN async via UDP protocol
v120 Async over ISDN
you can use keyword "none".
or just enable only ssh, which I prefer.
Perfect..exactly what I needed. Thanks
if it helps, rate the post
I'm also trying to turn off telnet, how do you just turn on ssh?
transport input ssh
David
To enable SSH and disable telnet configure this under all your vty lines:
transport input ssh
That will enable SSH and will not enable telnet. For SSH to work you will need to generate RSA keys.
Rick
Rick
