Trying to understand NAT & VLANs, with Cable modem to Catalyst router
bHubTel1610c
Hello All;
I check in with this issue a few months ago, but got off on some other subjects.  I'm a student at local community college and I have one class, basic Cisco routers, under my belt so I am dangerous.  I'm registered for two classes in Cisco routers starting in January, so I'm trying to refresh my mind about routing, LANs, etc.
To recap, a friend gave me a 1711 Catalyst router, which is somewhat old.  But it works.  I want to try to run it behind a cable modem to the internet and hook 2 computers and game console up to the 4 port switch card  (4esw).  As I understand it, the router should be programmed for NAT, so that the internal hosts (inside) get routed  to the one connection (fastethernet 0) that connects to the cable modem.  The switch card (layer 2) connects to the router via VLAN.
If I set up a computer with a static address (192.168.1.? 255.255.255.0), I can ping from computer to switch card and from computer to the ip address that the fa0 port picks up from the cable modem via dhcp.  But I get nothing from the internet.
Here's my running-config.
Router#show running-config
Building configuration...
Current configuration : 1013 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0
description connection to cable modem
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
ip nat inside
interface Async1
no ip address
ip classless
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Vlan1 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
line 1
line aux 0
line vty 0 4
end
Does anyone have any ideas?
Thanks, in advance, for any help or insight you can send my way.
-Bruce
2 Accepted Solutions
cadet alain
this NAT config is wrong: ip nat inside source list 101 interface Vlan1 overload
It should be
ip nat inside source list 101 interface fastethernet0  overload
if you want computers to get a DHCP address from the router you can do this:
ip dhcp excluded address 192.168.1.1
ip dhcp pool mypool
import all
network 192.168.1.0 /24
default-router 192.168.1.1
Regards.
Alain
Hi Bruce,
no problem.
1) indeed you are translating your private addresses from the LAN to the outside public address provided by the ISP so
   your  ip nat inside and ip nat outside interfaces were correct but not the NAT overload config because you told the  router to translate an inside address to an inside address. You must tell it to translate from inside to outside.
2) the excluded address is excluded from the pool you create below that will serve your clients, it has nothing to do with the ISP dhcp address your outside interface is getting.
The only link with the pool from ISP here is the import all command which will inherit dhcp options you didn't explicitly configured from the ISP pool like for example a list of DNS servers.
If the ISP didn't send you this option via DHCP then you can either explicitly configure it under your pool with the dns-server x.x.x.x  command and in this case you have 2 choices:
-list the dns servers from ISP or any public dns server like the one from Google( 8.8.8.8)
-list your router as dns server but then you'll have to configure the router for proxy-dns like this:
ip domain-lookup
ip name-server  x.x.x.x
ip dns-server
Regards.
Alain.
7 Replies 7
bHubTel1610c
BTW, I do not get an ip address from the router to computers automatically.  Hence the reference to setting up a static ip address to ping back out to cable modem.
Thanks!
-Bruce
Hi bHubTel1610c,
So, LAN clients dont use DHCP ...
Can they do a traceroute to their (static) DNS ?
Cheers!
cadet alain
It should be
ip dhcp pool mypool
import all
Regards.
Alain
Hi, Cadet;
Some questions, since I'm trying to understand exactly what I'm doing.
  1. Since fastethernet 0 is hooked to cable modem, I thought the "ip nat inside....." would be for vlan connection, since it translates the inside addresses to outside.  Could you explain that a little more?
  2. The dhcp address that the router would receive from the cable modem would never include a private address like 192.168.1.1, so is it necessary to "exclude" it from the list?
I'm not doubting you (I know that I don't know very much), it's just that I'm trying to understand what's going on.
Could you clarify, please?
Thanks!
-Bruce
Hi Bruce,
no problem.
ip domain-lookup
ip dns-server
Regards.
Alain.
Alain;
That did the trick.  Your help has been invaluable.
Just so I understand, the overload command needed to tell the router that the addresses and packets coming from inside needed to be translated to the fa0 interface connected to the cable modem (outside), but was instead being "reflected" back to the inside, since it referenced vlan1 instead.
Also, the excluded-address was due to the ip address of the vlan1 was configured as a static address, so it wouldn't assign that address to one of the other hosts.
Once again, thanks for your help.
-Bruce
Orlando, FL.
Hi Bruce,
Yes what you are saying is correct.
Regards.
Alain.
