Tunnel adapter Local Area Connection* :: Why do I have so many Tunnel adapters and how to get rid of them
JackDanial23
Tunnel adapter Local Area Connection* 28:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #17
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
Tunnel adapter Local Area Connection* 29:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #18
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter Local Area Connection* 30:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #19
Rajeev Sharma
Hey Jack,
These are used by VM's installed in the system, check how many you have running in your machine. You may remove them with following steps:
  • Open Start Menu
  • Type In: Device Manager
  • Select Device Manager
  • Click the View menu from the top
  • Select Show Hidden Devices (Must be check before continuing)
  • Scroll down and expand Network Adapters
  • Right-Click a duplicated Microsoft 6to4 Adapter or Microsoft ISATAP Adapter
  • Select Uninstall
  • Click OK for the pop-up warning message
  • Repeat and repeat for each of the unwanted duplicated adapter
  • Close Device Manager when finish
HTH.
Regads,
RS.
Rajeev Sharma
Hey Jack,
  • Open Start Menu
  • Select Uninstall
HTH.
Regads,
RS.
this helps
JackDanial23
Thanks rajeevsh , that helped !!
