07-18-2016 11:48 PM - edited 03-08-2019 06:41 AM
How Twinax Cable works in corporate networking .
07-19-2016 01:19 AM
this is very generic question with many answers , as one example twinax are a lot cheaper than fibre cables and can be used to connect fex switches to parent 5ks and 7ks in a data centre setup rather than using expensive fibre everywhere to reduce costs , this is important if you have large dc setups , they are also used in ToR solutions with servers to switch connections
They are limited in distance though compared to fibre currently
07-19-2016 03:51 AM
Hi Mark ,
Thank you for your response !
My scenario is below :
We have 3850 48P switches are there . we need to connect one ESX server .But that should be 10G connection . As all the 48 port over swtch having 1 gbps port .
So please let me is there any possibilities to connect 10 Gbps to the ESX cluster .
07-19-2016 04:27 AM
You should be able to get a 10g module for that switch and use twinax at 10gb with correct software as below
Catalyst 3850 Series |
Network Device |
Transceiver Model |
Minimum Software Release Required |
DOM Support |
Software Release |
WS-C3850-24T |
SFP-H10GB-CU1M |
XE 3.2.0SE |
SFP-10G-SR |
XE 3.2.0SE |
XE 3.2.0SE |
SFP-10G-ZR |
XE 3.3.3SE |
XE 3.3.3SE |
CWDM SFP+ |
XE 3.7.0 |
XE 3.7.0 |
SFP-H10GB-CU1-5M |
XE 3.6.0E |
SFP-10G-BXD-I |
XE 3.7.1E |
XE 3.7.1E |
07-19-2016 09:22 AM
Hi Mark ,
10 G module will be having 8 ports . But I need atleast 20 ports from my 3850 switch .
As this switch having 48 ports . I wanted to connect out of that 48 ports. 10 G module will be for uplink .
Any other option ?
07-20-2016 12:55 AM
are you saying you need 20x10gb ports off a 48 port 1gb port switch ?
