Two different network configuring in cisco switch
adm.mehedi
Dear all,
Good afternoon,
I am in problem it is very silly problem. I want to add two different network in Cisco 2950 series, is it possible?
But i don't want to use InterVlan Routing.
Two uplink network is 192.168.10.0/24 & 172.30.10.0/24
With regards
Mehedi Hasan
Dan Lukes
Feedback Forum is dedicated to other topics, see specification for details, so it has been off-topic in it. I moved it to LAN, Switching and Routing.
Please use red [ DELETE ] and [ DELETE ] button to delete two duplicates of the same thread you created.
Thank you for understanding.
Hi Mehedi,
There are multiple ways to do this . i guess, below is one of the easiest way  .
interface Vlan192
ip address 192.168.10.0 255.255.255.0
ip access-group 192 in
end
Current configuration : 83 bytes
interface Vlan172
ip address 172.30.10.0 255.255.255.0
ip access-group 172 in
end
Switch#sh access-list 192
Extended IP access list 192
    10 deny ip any 172.30.10.0 0.0.0.255
    20 permit ip any any
Switch#sh access-list 172
Extended IP access list 172
    10 deny ip any 192.168.10.0 0.0.0.255
VS.Suresh.
*Plz rate the usefull posts *
devils_advocate
Level 7
Level 7
The 2950 is a Layer 2 ONLY switch, it has no ability to do any Layer 3 routing.
You can create as many Layer 2 Vlans as the switch will allow but they will not be able to talk to each other unless you have a Layer 3 device somewhere which can route between them.
You can create two separate Vlans on the 2950 and you can use whichever IP ranges you want (the ranges are irrelevant) but unless you have a Router or a Layer 3 capable switch on the network, they will not be able to route anywhere.
