Two static routes to the same destination not working
ramyacruz
I am trying to configure a 3850 switch to be able to route to destinations 192.168.XXX.21 and 192.168.YYY.21 via two routers. I have sub-interface between the router and the switch for connectivity. RT1 is 10.20.XX.1 and RT2 is 10.20.YY.1. The problem I am currently having is that I am able to reach only one destination when source it from 10.20.XX.5 and the other when I source it from 10.20.YY.5, but not both. Both routers have connectivity to both destination subnets.
ip route 192.168.XXX.0 255.255.255.0 10.20.XX.1
ip route 192.168.XXX.0 255.255.255.0 10.20.YY.1
ip route 192.168.YYY.0 255.255.255.0 10.20.XX.1
ip route 192.168.YYY.0 255.255.255.0 10.20.YY.1
Please post the output of 'sh ip route'. Could you also post the output of 'traceroute 192.168.XXX.21 source 10.20.YY.1' and 'traceroute 192.168.XXX.21 source 10.20.XX.1' while replacing XXX and YY with the actual numbers.
HTH,
Meheretab
HTH,
Meheretab
17 Replies 17
HTH,
Meheretab
HTH,
Meheretab
Is it working for you? Is the problem fixed? Please let us know.
HTH,
Meheretab
HTH,
Meheretab
Its still not working and here is the sh ip route and traceroute outputs.
S     192.168.228.0/24 [1/0] via 10.20.32.1
                                        [1/0] via 10.20.30.1
S     192.168.238.0/24 [1/0] via 10.20.32.1
SW#traceroute 192.168.228.21
Tracing the route to 192.168.228.21
VRF info: (vrf in name/id, vrf out name/id)
  1 10.20.30.1 2 msec *  1 msec
  2  *  *
SW#traceroute 192.168.238.21
Tracing the route to 192.168.238.21
  1 10.20.30.1 1 msec *  2 msec
  2  *  *  *
SW#ping 192.168.228.21 source vlan 277
Sending 5, 100-byte ICMP Echos to 192.168.228.21, timeout is 2 seconds:
Packet sent with a source address of 10.20.30.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/9/9 ms
SW#ping 192.168.228.21 source vlan 278
Packet sent with a source address of 10.20.32.5
Success rate is 0 percent (0/5)
SW#ping 192.168.238.21 source vlan 277
Sending 5, 100-byte ICMP Echos to 192.168.238.21, timeout is 2 seconds:
SW#ping 192.168.238.21 source vlan 278
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/12/12 ms
Thank you for providing more information! You have two routes which are supposed to work; however, the Ping output showed that it works from one of the networks. Do you have an ACL running? Could you share the output of 'sh run'?
HTH,
Meheretab
HTH,
Meheretab
I don't have any ACLs in place.
However, if I have only the below routes, I am able to reach the both destination subnets through the same next hop but when I introduce two more static routes  with a different next hop, the system gets confused and routes differently.
I also tried with IP SLA tracking and added backup route to go via a different router, in that case it is doing what it is supposed to do. But, my question here is if it has two routes to the same destination via different next hops, it should route through both right?
Thank you for your input.
 It should perform load balancing when you have two routes with the same longest prefix match and same AD.
Please post the output of 'sh ip route 192.168.228.21', 'sh ip route 192.168.238.21', 'sh ip cef 192.168.228.21',  and 'sh ip cef 192.168.238.21'.
HTH,
Meheretab
HTH,
Meheretab
SW#sh ip route 192.168.228.21
Routing entry for 192.168.228.0/24
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
10.20.32.1
Route metric is 0, traffic share count is 1
* 10.20.30.1
SW#sh ip route 192.168.238.21
Routing entry for 192.168.238.0/24
10.20.32.1
* 10.20.30.1
SW#sh ip cef 192.168.228.21
192.168.228.0/24
nexthop 10.20.30.1 Vlan277
nexthop 10.20.32.1 Vlan278
SW#sh ip cef 192.168.238.21
192.168.238.0/24
CEF is the one which causes the router to send the packets on the same interface (or subinterface in your case). If possible, you could run 'debug ip icmp' and run a couple of PINGs. Do NOT forget to 'undebug ip icmp' when you are done with troubleshooting.
Run as follows and post the output:
debug ip icmp
ping 192.168.228.21 ( a couple of times)
ping 192.168.238.21 ( a couple of times)
undebug ip icmp
HTH,
Meheretab
HTH,
Meheretab
I don't think this is going to be of any help.
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/10/11 ms
SW#
Nov 8 18:03:10: ICMP: echo reply rcvd, src 192.168.228.21, dst 10.20.30.5, topology BASE, dscp 0 topoid 0
Nov 8 18:03:10: ICMP: echo reply rcvd, src 192.168.228.21, dst 10.20.30.5, topology BASE, dscp 0 topoid 0ping 192.168.228.21
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/10/11 ms
SW#
Nov 8 18:03:11: ICMP: echo reply rcvd, src 192.168.228.21, dst 10.20.30.5, topology BASE, dscp 0 topoid 0
SW#
Nov 8 18:04:20: ICMP: echo reply rcvd, src 192.168.228.21, dst 10.20.30.5, topology BASE, dscp 0 topoid 0
Nov 8 18:04:20: ICMP: echo reply rcvd, src 192.168.228.21, dst 10.20.30.5, topology BASE, dscp 0 topoid 0ping 192.168.228.21 source vlan 277
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/12/13 ms
SW#
Nov 8 18:05:06: ICMP: echo reply rcvd, src 192.168.238.21, dst 10.20.32.5, topology BASE, dscp 0 topoid 0
Actually, it is helpful. Thank you for sharing!
As you can see from the output of the 'ping 192.168.238.21 from 10.20.30.5', we were not receiving any icmp echo reply to the requests sent. It points to two things: either there is part of the configuration which forces load to be shared between two alternate routes (what I mean is, part of the networks will be reached with one gateway and the other part of the network is reached with the second gateway), or there is only one return route from the server network (which is pointing to 10.20.32.5 network when you have two routes).
So, please post the output of 'sh run'. You can change sensitive information before posting it.
HTH,
Meheretab
HTH,
Meheretab
The routers are connected to port 1/0/22 and 2/0/22.
version 16.6
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service compress-config
no platform punt-keepalive disable-kernel-core
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa authentication login default local
aaa authentication enable default line
aaa authorization exec default if-authenticated
aaa session-id common
boot system switch all flash:cat3k_caa-universalk9.16.06.01.SPA.bin
switch 1 provision ws-c3850-24p
switch 2 provision ws-c3850-24p
ip routing
spanning-tree mode pvst
redundancy
mode sso
hw-switch switch 2 logging onboard message
interface Port-channel1
switchport trunk allowed vlan 270-279,400-410
switchport mode trunk
interface Port-channel102
switchport trunk allowed vlan 400-410
switchport nonegotiate
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
speed 1000
negotiation auto
interface GigabitEthernet1/0/1
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/21
speed 1000
duplex full
channel-group 102 mode active
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
channel-group 1 mode active
interface GigabitEthernet1/0/24
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/21
speed 1000
duplex full
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface Vlan1
ip address 172.16.1.102 255.255.255.0
interface Vlan5
ip address 192.168.5.5 255.255.255.0
interface Vlan276
no ip address
interface Vlan277
ip address 10.20.30.5 255.255.255.0
interface Vlan278
ip address 10.20.32.5 255.255.255.0
ip default-gateway 172.16.1.254
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.1.254
ip route 192.168.228.0 255.255.255.0 10.20.30.1
ip route 192.168.228.0 255.255.255.0 10.20.32.1
ip route 192.168.238.0 255.255.255.0 10.20.32.1
ip route 192.168.238.0 255.255.255.0 10.20.30.1
I do not see any problem in the switch config. Please post the 'sh run' output of the routers as well.
HTH,
Meheretab
HTH,
Meheretab
I think the destination router has some sort of filtering and we don't control those routers so that was the issue. Thank you for your help.
Thank you for letting us know!
HTH,
Meheretab
