Two uplinks in core switch
vivekprajapati93
Frequent Visitor
Frequent Visitor
Hi Expert Team,
i had two uplink from location_1 core switch to location_2 core switch. And i want to configure these two like if one uplink goes down then other one is Auto up. Is this possible ? means i want to set up a high availability or failover configuration between my core switches at Location_1 and Location_2, so that if one uplink goes down, the other one automatically takes over.
DanielP211
Hello!
Best would be to setup a LACP configuration - portchannel. In this way both links will be up all the time. Another option is STP with RSTP. Or the last option in my opinion is REP (Resilient Ethernet Protocol).
IF you have any more questions ask.
BR
****Kindly rate all useful posts*****
Blue_Bird
I suggest...configure a  port-channel with  LCAP and enable appropriate load balancing method...
Best regards
******* If This Helps, Please Rate *******
L1 using LACP Port channel
L2 using STP
L3 using not Equal cost multi path
so these solution is available
your selection is depend on your network
Thanks A Lot
MHM
