txload and rxload relationship to input rate/output rate
Jason Jackal
Folks:
I have been reviewing the txload and rxload values in relationship to the input/output rate; however, I do not fully understand the difference between the four values. What is each value telling me?
From what I understand – txload and rxload take in account the interface bandwidth, but is the bandwidth value configured with the interface ‘bandwidth’ command?
If I want to know the average load on the interface – would I look under the following ‘sh int’ command output?
5 minute output rate 1000 bits/sec, 1 packets/sec
     454 packets input, 89091 bytes, 0 no buffer
This topic might have already been discussed in great detail; however, I am just having a hard time understanding without the social interaction.
Thank you.
19 Replies 19
Hi leolahoo:
Can I add something?
This is in regards to the value of X/255 (Txload & Rxload) and the value of 255/255 (Reliability).
The value of "255" means that your link is WORKING 100%.
If  you punch in the command "sh interface " and your Txload or  Rxload is showing like X/254 (or lower) then you have a potential cable  problem.
Same  goes with the Reliability value.  The value of 255/255 means it's  working great.  Two-thumbs-up.  However, if the either value dips to 254  and below then you have a cable issue.
Cable issue...good to know, which I will keep my eye out for.
Thanks.
Hi Jason,
Can I also add ANOTHER thing (Groan!)?
If you DO BELIEVE you have a cable issue then you can run a TDR directly from a Cisco switch.
kindly support guys
what does it mean when all interfaces txload255/255 while in monitoring system logs shown link not fully utilized
like 1G link in mentoring you will see about 400Mbps, but txload255/255.
Possibly your monitoring system and interface loads are working on different time windows and/or when a time window actually starts/ends.
i see 1min different.
let is forget about monitoring part , For the  txload 255/255 this happened to all interfaces , is it a bug on 7600 routers i mean it is weird kind of hardware issue or bug  ?
Note:-
i even tried my laptop it is directly connected  to the router , when i check the interface txload 255/255  no policy applied on interface.
