Typed wrong register value on Cisco 1700
dolgoteslo
When i was doing password reset on Cisco 1700 router i typed the wrong register value in rommon. So instead of 0x2102 i typed 0x2120. Now when i try to acces the router through console i see strange signs appear and i cannot do anything with the router. The ctrl+break or ctrl+shift+x sequence doesn't work.
How can i correct the problem?
Thanks for your help.
Best regards,
Janez
cadet alain
the confreg value you entered does this( taken from Boson config-register calculator):
NVRAM config will be used
Break key Disabled, after IOS load
Console Baud: 19200
Will Stay at the system bootstrap prompt (ROM monitor) on a reload or power cycle.
So change speed to 19200 on terminal emulator then change config-register back to 0X2102
Regards.
Alain.
cadet alain
Console Baud: 19200
Regards.
Alain.
Thanks! It Works!
