UC500 question...
imunoze00
Community Member
We recently setup a UC520W and it looks like for some reason it is blocking local communication between the client machines. We cannot ping from one pc to another, network printers, etc etc but we can do so to the uc500 and from it... it acts as if it was an isolated vlan, but it isn't. Any ideas?
Any help will be much appreciated
Amit Aneja
Level 8
Level 8
Please share the "sho run" from the router.
UCItelecom#sh run
Building configuration...
Current configuration : 27089 bytes
! Last configuration change at 16:27:25 CDT Tue Sep 6 2011 by itelecom
! NVRAM config last updated at 13:35:48 CDT Tue Sep 6 2011 by itelecom
version 15.0
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UCItelecom
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXX
--More--                           no aaa new-model
clock timezone CST -6
clock summer-time CDT recurring
crypto pki trustpoint TP-self-signed-3051726054
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3051726054
revocation-check none
rsakeypair TP-self-signed-3051726054
crypto pki certificate chain TP-self-signed-3051726054
certificate self-signed 01
  30820242 308201AB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33303531 37323630 3534301E 170D3131 30393032 32313139
  34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30353137
  32363035 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD2F D4686FF1 5D7DEA85 3010DB7F 668C9F92 6DFF211A AE8A1BBA 3F0B0AE5
--More--                             08879CA8 4076D4CE 8DDD553D 7440D2D4 6C13F736 1CDB9DAA E8E3BC9C 179A177E
  FF77054D DA37C132 457700D0 8512EC20 D303E3A4 4F7DE89E 94B5D5F9 5E881B76
  6948C73D 492156B9 6A5C0EA1 1829297E 85FCA2AA 8FC42FEA 35EE54D4 1B1888B8
  DF8F0203 010001A3 6A306830 0F060355 1D130101 FF040530 030101FF 30150603
  551D1104 0E300C82 0A554349 74656C65 636F6D30 1F060355 1D230418 30168014
  2A8263F2 6634A687 D836451D AE91BD56 1F834904 301D0603 551D0E04 1604142A
  8263F266 34A687D8 36451DAE 91BD561F 83490430 0D06092A 864886F7 0D010104
  05000381 8100848D C9D4D4B9 3A38CEB6 134E580E 0D11E848 05C096B6 4D036E41
  035D4ADD 4DC9F601 F4B6BA74 F34881BB 7BF13B07 04844905 4AC26AA8 FFD1B9E2
  62861CB2 91A9A3A6 B400DA75 29AF50E6 0E9EF38F 2F483DD9 E8F828B2 8C0876D8
  5F70A8A5 A8FF21E0 30700548 938F028D 204D6633 AB29D5F9 0761C7B9 3C9A9E3E
  4269AFCF A23C
      quit
dot11 syslog
dot11 ssid cisco-voice
vlan 100
authentication open
dot11 ssid iTelecom
vlan 1
authentication open
authentication key-management wpa
--More--                            guest-mode
wpa-psk ascii 0 XXXXXXXX
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.1.1 192.168.1.199
ip dhcp excluded-address 192.168.1.241 192.168.1.255
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
--More--                           !
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
--More--                           stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/0/0
  fallback-dn 301
port 0/0/1
  fallback-dn 302
port 0/0/2
  fallback-dn 303
port 0/0/3
  fallback-dn 304
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
--More--                           voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
voice hunt-group 1 parallel
--More--                            final 399
list 201,202,204,205
timeout 16
pilot 511
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
--More--                           voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
license udi pid UC520W-8U-4FXO-K9 sn FHK1135130M
archive
log config
  logging enable
  logging size 600
  hidekeys
--More--                           username itelecom privilege 15 secret 5 $1$FTw5$kKcpOQP9n54SmtUwTd1Py0
ip tftp source-interface Loopback0
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
bridge irb
--More--                           !
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp client-id FastEthernet0/0
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
--More--                            description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
--More--                            spanning-tree portfast
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
--More--                            macro description cisco-phone
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid cisco-voice
ssid iTelecom
--More--                            !
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
world-mode dot11d country MX indoor
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
--More--                            no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip access-group 102 in
ip nat inside
--More--                           interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
--More--                           access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip 192.168.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
--More--                           access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.1.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 deny   ip 192.168.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any log
--More--                           !
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7921/APPS-1.3.3.SBN alias APPS-1.3.3.SBN
--More--                           tftp-server flash:/phones/7921/CP7921G-1.3.3.LOADS alias CP7921G-1.3.3.LOADS
tftp-server flash:/phones/7921/GUI-1.3.3.SBN alias GUI-1.3.3.SBN
tftp-server flash:/phones/7921/MISC-1.3.3.SBN alias MISC-1.3.3.SBN
tftp-server flash:/phones/7921/SYS-1.3.3.SBN alias SYS-1.3.3.SBN
tftp-server flash:/phones/7921/TNUX-1.3.3.SBN alias TNUX-1.3.3.SBN
tftp-server flash:/phones/7921/WLAN-1.3.3.SBN alias WLAN-1.3.3.SBN
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
--More--                           tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
--More--                           tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
--More--                           control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
cptone MX
station-id number 401
caller-id enable
voice-port 0/0/1
cptone MX
station-id number 402
caller-id enable
voice-port 0/0/2
cptone MX
station-id number 403
caller-id enable
voice-port 0/0/3
cptone MX
--More--                            station-id number 404
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
cptone MX
connection plar opx 511
description Configured by CCA 4 FXO-0/1/0-Custom-BG
caller-id enable
voice-port 0/1/1
cptone MX
connection plar opx 401
description Configured by CCA 4 FXO-0/1/1-Custom-OP
caller-id enable
voice-port 0/1/2
cptone MX
connection plar opx 399
description Configured by CCA 4 FXO-0/1/2-OP
caller-id enable
--More--                           !
voice-port 0/1/3
cptone MX
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
--More--                            name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
--More--                           !
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
--More--                            member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
--More--                           !
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
--More--                            description ** incoming dial peer **
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
--More--                            destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 6 pots
--More--                            description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 65 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*Mexico*International Calls**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 900T
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*Mexico*LADA**
preference 5
destination-pattern 901..........
forward-digits all
--More--                            no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
corlist outgoing call-national-plus
description **CCA*Mexico*Long Distance Mobile**
preference 5
destination-pattern 9045..........
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*Mexico*Emergency**
preference 5
destination-pattern 9066
forward-digits all
no sip-register
dial-peer voice 69 pots
--More--                            trunkgroup ALL_FXO
preference 5
destination-pattern 066
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
corlist outgoing call-local-plus
description **CCA*Mexico*Local Mobile Numbers**
preference 5
destination-pattern 9044..........
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
description **CCA*Mexico*Local Calls - 7, 8 or 10 digits depending on loca**
--More--                            preference 5
destination-pattern 9[1-9]T
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone SPA525-wifi-on yes
service phone SPA525-protocol SPCP
service phone SPA525-auto-detect-sccp yes
service phone SPA525-http-write yes
--More--                            service phone SPA525-SSID cisco-voice
service phone SPA525-readonly no
service phone SPA525-Encryption-type DISABLE
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Itelecom
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.3
load 521G-524G cp524g-8-1-17
time-zone 8
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$LueE$BYPOgzzgSJk4ep/WZBDMN0
dn-webedit
time-webedit
--More--                            transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Sep 02 2011 14:48:07
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
--More--                            softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
--More--                            moh out-call ABC
ephone-dn  12  dual-line
number 203 no-reg primary
label 203
description 203
name 203
ephone-dn  13  dual-line
number 204 no-reg primary
label 204
description Cesar Alonso
name Cesar Alonso
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn  14  dual-line
number 205 no-reg primary
label 205
description Ignacio Munoz
--More--                            name Ignacio Munoz
ephone-dn  15  dual-line
number 206 no-reg primary
label 206
description 206
name 206
ephone-dn  16  dual-line
number 207 no-reg primary
label 207
description 207
name 207
ephone-dn  17  dual-line
number 208 no-reg primary
label 208
description 208
--More--                            name 208
ephone-dn  18  dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn  19  dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone-dn  52  octo-line
number 202 no-reg primary
label 202
description Guadalupe Chagolla
name Guadalupe Chagolla
--More--                            call-forward noan 399 timeout 20
ephone-dn  53  octo-line
number 201 no-reg primary
label 201
description Juan Casillas
name Juan Casillas
ephone-dn  54
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  55
number A801... no-reg primary
mwi off
--More--                           ephone-dn  56
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 001F.6C79.FD28
ephone-template 16
max-calls-per-button 4
username "jcasillas" password 12345
type 7921
button  1:53
ephone  2
mac-address 001F.6C79.FBFC
ephone-template 16
username "gchagolla" password 123456
type 7921
--More--                            button  1:52
ephone  5
mac-address 001E.4AF1.BEDC
ephone-template 16
username "CAlonso" password 123456
type 7906
button  1:13
ephone  6
mac-address 001E.4AF1.C1E9
ephone-template 16
username "IMunoz" password 123456
type 7906
button  1:14
--More--                           alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.1 (1). Fri Sep 02 13:59:31 CDT 2011^^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
login local
line vty 5 100
login local
ntp master
end
UCItelecom#  exit
El mensaje fue editado por: Ignacio Munoz
I believe that the two devices that can't talk are in vlan 1. Where are the devices connected (are they directly connected on the router HWIC or are they connected on a downstream switch)?
What are the IP addresses of both machines? Let's create an ACL for debugging & see what's happening. I have assumed 192.168.1.x & .y as the client machines.
ip access-list ex 191
permit ip host 192.168.1.x host 192.168.1.y
permit ip host 192.168.1.y host 192.168.1.x
enable debugging
debug ip packet 191
ping from 192.168.1.x to 192.168.1.y
Plz share the debug results.
Amit
as you accurately pointed out, they are all connected to vlan 1 through the wireless interface. Now, regarding the ACL you suggest; you believe that access-list 102 could be causing the problem?? or which access-list would you think is preventing the client machines from communicating?
