UDLD on Nexus 5548
luke.smith
Does UDLD work between the Nexus 5548 and a Nexus FEX 2248 and would there be any benefit?
Luke
Mark Malone
Hey I didn't think 2248s supported udld and for it to work right both sides 5 & 2 must be able to support it
You can check with show interface Ethernet x/x/x capabilities
I could be wrong now they may have changed it but I remember seeing before when I checked this it stated no under capability support for udld
Hi Mark,
Thanks for your response - I know the Ports on the FEX dont support UDLD but what about the Uplink ports? (FET ports to Nexus 5K)
These dont show as interfaces on the 5K
Luke
Hi Luke,
You can see the fex uplink ports with this command.
show interface fex-fabric
For more information:
show fex xxx detail
Greetz,
Jeroen
russell.sage
Level 3
Level 3
On a related issue if I enable the UDLD feature in a production network do all the fiber ports automatically enable UDLD, as per the documentation. Cisco Nexus 5000 Series NX-OS Layer 2 Switching Configuration Guide, Release 5.0(3)N2(1) - Configuring Ethernet Interfaces [Cisco Nexus 5000 Series Switches] - Cisco
Default UDLD Configuration
The following table shows the default UDLD configuration.
Table 1  UDLD Default Configuration
Feature
Default Value
UDLD global enable state
Globally disabled
UDLD aggressive mode
Disabled
UDLD per-port enable state for fiber-optic media
Enabled on all Ethernet fiber-optic LAN ports
UDLD per-port enable state for twisted-pair (copper) media
Disabled on all Ethernet 10/100 and 1000BASE-TX LAN ports
