UDP port forwarding
erloumiguel
We have a setup of a firewall in between my Cisco 1841 router and Switch.
Cisco Router --> Meraki Firewall--> Switch
Client VPN is configured on the Meraki Firewall but then for the outside users to client vpn in to the network, I have to port forward or open the ports 500 and 4500 to the IP address of the Meraki Firewall 192.168.1.90
I tried to play around with the natting but it was uncessful. Please kindly advise.
Here is the sh run
M5Router>en
M5Router#sh run
Building configuration...
Current configuration : 746 bytes
version 12.4
hostname M5Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
ip name-server 165.21.83.88
ip name-server 165.21.100.88
interface FastEthernet0/0
ip address dhcp
ip nat outside
speed 100
full-duplex
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 dhcp 100
ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Thanks for your help.
blau grana
Level 7
Level 7
Hello Erlou,
Did you try?
ip nat inside source static udp 192.168.1.90 500 interface Fa0/0 500
ip nat inside source static udp 192.168.1.90 4500 interface Fa0/0 4500
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Jan Rolny
Level 3
Level 3
you will probably need to configure something like below. I am not sure if you can make NAT on interface where DHCP IP is configured instead of static IP.
This translate from inside to outisde when using port 80 (HTTP). So all client from internet accessing 10.0.0.1 will get response from HTTP server inside network(192.168.1.3)
ip nat inside source static tcp 192.168.1.90 80 10.0.0.1 80
Your configuration do all inside host are behind outside interface IP which may vary depend on DHCP lease from your provider.
Jan
Jan Rolny
Level 3
Level 3
Blau Grana is right. But be careful when your outside IP will change
Best Regards,
Jan
Thanks.
we have resolved the issue, we just added a static route and it works.
ip route 192.168.2.0 255.255.255.0 192.168.1.90
192.168.2.0 is the client VPN network and the destination is the IP of the Firewall
