switch 2960, 3750 stacking
how to stack 2 switches catalyst 2960 also haw to stack 2 cisco 3750 switches please provide me ?????
InayathUlla Sharieff
Hi Mohammed,
Not sure if you have looked at the below links:
Stacking 2960:-
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Stacking 3750:
http://www.cisco.com/en/US/partner/products/hw/switches/ps5023/products_configuration_example09186a008078
Easy way:
1.  Power up the switch master (ONLY!);
2.   Attach the stacking cable to the rest of the members;
3.  Power up the members ONE-AT-A-TIME and based on the order of your choice.
Example, if switch 2 is the 2nd switch, then power this switch after the master has been powered up and stacking cable has been applied.
Rules-of-the-Thumb:
1.  Ensure all switches are running the same IOS version, same Feature Set (example IP Base);
2.  Once all switches are up, ensure you enable "switch n priority XX";
HTH.
Inayath
*Plz rate the usefull posts.
Hi Mohammed,
Stacking 2960:-
Stacking 3750:
Easy way:
Rules-of-the-Thumb:
HTH.
Inayath
thank you friend
ASAK Mohamed,
I am glad the information has been helpfull to you.
Could you please mark the query as answered( so that it helps others who has same query.) rather than leaving it as question still  NOt Answered.
Inayath
*Please rate useful posts and remember to mark any solved questions as answered. Thank you.
