unable to access standby sup engine
gmvburg23
the ws-x6k-s2u-msfc2 is the standby sup engine and a ws-x6k-sup2-2ge is the primary. when removing the primary and starting to boot the secondary it hangs and goes to rommon but unable to type. if i place console cable into standby not able to type.
sadbulali
Level 4
Level 4
This issue may be due the slot that supervisor engine is mounted. If the slot is different and if you access wrong slot then the suervisor cannot be accessed.
