Unable to boot a ws-c2960-48tc-l, recovered switches and routers before but this one stuck me.
thompson318
Any suggestions??
This is where I'm at:
I'm using Secure CRT with a baud rate of 115220
switch: set BAUD 115200
switch: format flash:
switch: copy xmodem: flash:c2960-lanbasek9-mz.150-2.SE6.bin
switch: set BAUD 9600
switch: boot flash:c2960-lanbasek9-mz.150-2.SE6.bin
switch: boot
Loading "c2960s-universalk9-mz.152-1.E2.bin"...c2960s-universalk9-mz.152-1.E2.bin: no such device
or
Loading "flash:c2960-lanbasek9-mz.150-2.SE6.bin"...flash:c2960-lanbasek9-mz.150-2.SE6.bin: magic number mismatch: bad mzip file
Error loading "flash:c2960-lanbasek9-mz.150-2.SE6.bin"
Leo Laohoo
If you're at ROMmon, do the following:
flash_init
dir flash:
Post the output to the last command.
One more thing, before you uploaded the BIN file to the switch, did you happen to compare the MD5 hash value of the BIN file against the MD5 hash value found in the Cisco website?  They need to match or your effort is futile.
osamasalman
hello
here is some links for your reference:
http://www.youtube.com/watch?v=zxTO5qxti-I
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/15085-xmodem-generic.html
please note, if there is no enough space on the flash to handle the new and the old IOS image, i would suggest you to upload old/small IOS to fits into the flash, then you can delete the old corrupted one and to upgrade to new IOS image...
Kind Regards,
/Osama
