Unable to connect to DMZ and WAN via LAN
HadiBeheshti
Hi, I have a 3750 switch and three 2960 switches and a Kerio firewall.
IP range of 2960 switches: 10.10.31.0/24, 10.10.32.0/24, 10.10.41.0/24
DMZ IP Range: 10.10.10.0/24
LAN IP Range: 10.10.12.0/24
WAN IP Range: 180.140.32.0/24
IP Kerio: 10.10.10.2
Computers on the LAN can see each other. But they do not have access to the server. And do not see DMZ and WAN.
I defined a VLan for DMZ and a separate VLan for LAN.And a VLan for each of the 2960 switches that give devices IP through DHCP.
Thanks for pointing me to how I can modify the code.
I attached the code I used below.
3750 :
enable
configure terminal
hostname SW-Core
ip default-gateway 10.10.10.2
ip domain-name ********
vtp mode server
vtp domain ********
vtp version 2
vtp pruning
enable secret ********
line vty 0 15
password ********
login
exit
line console 0
password ********
login
exit
VLan 10
name DMZ
exit
VLan 12
name CORE
exit
VLan 31
name F3N
exit
VLan 32
name F3S
exit
VLan 41
name F4N
exit
interface vlan 10
ip address 10.10.10.11 255.255.255.0
no shutdown
exit
interface vlan 12
ip address 10.10.12.1 255.255.255.0
no shutdown
exit
interface vlan 31
ip address 10.10.31.1 255.255.255.0
no shutdown
exit
interface vlan 32
ip address 10.10.32.1 255.255.255.0
no shutdown
exit
interface vlan 41
ip address 10.10.41.1 255.255.255.0
no shutdown
interface range gigabitEthernet 1/0/1-6
switchport mode trunk
switchport trunk allowed vlan 1-99
no shutdown
exit
interface range gigabitEthernet 1/0/7-9
switchport mode access
switchport access vlan 10
no shutdown
exit
interface range gigabitEthernet 1/0/10-12
switchport access vlan 12
no shutdown
exit
interface range gigabitEthernet 1/0/13-28
shutdown
exit
ip dhcp pool DMZ
network 10.10.10.0 255.255.255.0
default-router 10.10.10.11
dns-server 10.10.10.2
lease 8
exit
ip dhcp pool CORE
network 10.10.12.0 255.255.255.0
default-router 10.10.12.1
dns-server 10.10.10.10
lease 8
exit
ip dhcp pool F3N
network 10.10.31.0 255.255.255.0
default-router 10.10.31.1
lease 8
exit
ip dhcp pool F3S
network 10.10.32.0 255.255.255.0
default-router 10.10.32.1
lease 8
exit
ip dhcp pool F4N
network 10.10.41.0 255.255.255.0
default-router 10.10.41.1
lease 8
exit
ip routing
ip dhcp excluded-address 10.10.10.1 10.10.10.12
ip dhcp excluded-address 10.10.12.1 10.10.12.10
ip dhcp excluded-address 10.10.31.1 10.10.31.10
ip dhcp excluded-address 10.10.32.1 10.10.32.10
ip dhcp excluded-address 10.10.41.1 10.10.41.10
exit
write
2960 :
enable
configure terminal
hostname SW-F3N
vtp mode client
vtp domain ********
ip default-gateway 10.10.31.1
line vty 0 15
password ********
login
exit
line console 0
password ********
login
exit
interface gigabitEthernet 0/24
no shutdown
exit
interface range gigabitEthernet 0/21-23
shutdown
exit
interface range gigabitEthernet 0/1-20
switchport access vlan 31
no shutdown
exit
interface vlan 1
no ip address
shutdown
exit
interface vlan 31
ip address 10.10.31.2 255.255.255.0
no shutdown
exit
exit
write
10 Replies 10
the configs look good. The only thing that needs to be removed is:
hostname SW-Core
--> no ip default-gateway 10.10.10.2
Are the Vlan interfaces up/up ? Post the output of:
sh ip int brief
from the core switch.
Thanks for your answer, I executed the command you said and now I can ping LAN computers through Kerio, but I can't ping DMZ servers and even Kerio through LAN computers. Do I have to write a specific route? I ordered
ip route 0.0.0.0 0.0.0.0 VLan 10 10.10.10.2
I did it in 3750 but it didn't work.
I added the result of the Tracert command in two ranges: DMZ, WAN and the command you mentioned
SW-Core#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES unset  up                    up
Vlan10                 10.10.10.11     YES manual up                    up
Vlan12                 10.10.12.1      YES manual up                    up
Vlan31                 10.10.31.1      YES manual up                    up
Vlan32                 10.10.32.1      YES manual up                    up
Vlan41                 10.10.41.1      YES manual up                    up
Vlan42                 10.10.42.1      YES manual up                    up
Vlan51                 10.10.51.1      YES manual up                    up
Vlan52                 10.10.52.1      YES manual up                    up
GigabitEthernet1/0/1   unassigned      YES unset  up                    up
GigabitEthernet1/0/2   unassigned      YES unset  down                  down
GigabitEthernet1/0/3   unassigned      YES unset  down                  down
GigabitEthernet1/0/4   unassigned      YES unset  down                  down
GigabitEthernet1/0/5   unassigned      YES unset  down                  down
GigabitEthernet1/0/6   unassigned      YES unset  down                  down
GigabitEthernet1/0/7   unassigned      YES unset  down                  down
GigabitEthernet1/0/8   unassigned      YES unset  down                  down
GigabitEthernet1/0/9   unassigned      YES unset  up                    up
GigabitEthernet1/0/10  unassigned      YES unset  down                  down
GigabitEthernet1/0/11  unassigned      YES unset  down                  down
GigabitEthernet1/0/12  unassigned      YES unset  up                    up
GigabitEthernet1/0/13  unassigned      YES unset  administratively down down
GigabitEthernet1/0/14  unassigned      YES unset  administratively down down
GigabitEthernet1/0/15  unassigned      YES unset  administratively down down
GigabitEthernet1/0/16  unassigned      YES unset  administratively down down
GigabitEthernet1/0/17  unassigned      YES unset  administratively down down
GigabitEthernet1/0/18  unassigned      YES unset  administratively down down
GigabitEthernet1/0/19  unassigned      YES unset  administratively down down
GigabitEthernet1/0/20  unassigned      YES unset  administratively down down
GigabitEthernet1/0/21  unassigned      YES unset  administratively down down
GigabitEthernet1/0/22  unassigned      YES unset  administratively down down
GigabitEthernet1/0/23  unassigned      YES unset  administratively down down
GigabitEthernet1/0/24  unassigned      YES unset  administratively down down
GigabitEthernet1/0/25  unassigned      YES unset  administratively down down
GigabitEthernet1/0/26  unassigned      YES unset  administratively down down
GigabitEthernet1/0/27  unassigned      YES unset  administratively down down
GigabitEthernet1/0/28  unassigned      YES unset  administratively down down
tracert 10.10.10.2(Firewall)
Tracing route to 10.10.10.2 over a maximum of 5 hops
  1    <1 ms    <1 ms    <1 ms  10.10.31.1
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
Trace complete.
tracert 172.80.10.1(WAN)
Tracing route to 172.20.1.1 over a maximum of 5 hops
Trace complete.
at this point it gets confusing what works and what does not work. Post a drawing of your topology including all devices and IP addresses, and how they are connected.
I posted
HadiBeheshti
Sorry for bad drawing
Kerio Routing Table :
the drawing is very good actually !
Make sure all Vlans actually exist on the Core switch. When you issue the command 'sh vlan' , all Vlans should be listed. If they are not there, you might have to manually create them, e.g.:
SW-Core#conf t
SW-Core(config)#vlan 10
Also, make sure that both the PC and the Kerio use the IP address of the respective SVI of the core switch as the default gateway:
Kerio default gateway
--> 10.10.10.11
PC default gateway
--> 10.10.31.1
This is exactly the problem. Kerio uses the wan address as its gateway. Other servers use kerio dmz ip as gateway (10.10.10.2). But vlan10 has its own gateway (10.10.10.11) and vlan12 has its own gateway (10.10.12.1).
Now computers connected to a 2960 switch and then 2960 switch connected to the core switch via a trunk cannot see the dmz.
In core switch, the ports are as follows
Ports 1 to 6: Trunk for connecting 2960 switches. With own DHCP and gateway
(10.10.31.1,10.10.32.1,10.10.41.1)
Port 7-9: Intended for use by DMZ with Gateway 10.10.10.11
Port 10-12: Intended for LAN.
On the server
Nic0: LAN
Nic1,2: DMZ
Nic3: WAN
In ESXi
Server installed on ESXi were used vlan10 IP range manually, but with Kerio Gateway (10.10.10.2)
HadiBeheshti
May someone help me
