Unable to connect two switches using two vlans and two physical connections
elvinhokarhoe
Hi Experts,
I've set up the following configuration:
PC A --- SW A --- SW B --- SVR A (via VLAN 2)
PC B --- SW A --- SW B --- SVR B (via VLAN 3)
I've set:
1. two vlan 2 access ports on switch A to connect PC A and SW B
2. two vlan 3 access ports on switch A to connect PC B and SW B
3. two vlan 2 access ports on switch B to connect SW A and SVR A
4. two vlan 3 access ports on switch B to connect SW A and SVR B
all using separate physical ports and switchport mode access.
This setup does not work, is it the correct behavior or I missed out somthing?
Cheers,
Elvin
I could not understand why are you connecting an access port to the switch on other end (interface ethernet 1/g21 -- to SW B).
Please get the same configured as trunk and then pass the desired vlan from therein.
i.e.
PC-----access port -----SW A -------trunk port ---------------SW B ---------access port--------PC.
The trunk port can be configured to carry the desired vlans.
Parvesh
Note: Please do not forget to rate the post helpful if you find it worth.
5 Replies 5
Can you post the running config from the switches please?
Switch A:
interface ethernet 1/g1 -- to PC A
switchport access vlan 2
exit
interface ethernet 1/g2 -- to PC B
switchport access vlan 3
exit
exit
interface ethernet 1/g22 -- to SW B
exit
Switch B:
interface ethernet 1/g1 -- to SVR A
exit
interface ethernet 1/g2 -- to SVR B
exit
interface ethernet 1/g21 -- to SW A
exit
interface ethernet 1/g22 -- to SW A
exit
other ports are shutdown.
ip address of PC A: 192.168.1.10/24
ip address of PC B: 10.1.1.10/28
ip address of SVR A: 192.168.1.1/24
ip address of SVR B: 10.1.1.1/28
When you say "this setup does not work", could you be more specific please?  You need to break the problem down into sections for easy diagnosis.  For example, can each PC ping its own gateway address on the SVI?
  • Can PC A ping 192.168.1.1 ?
  • Can PC B ping 10.1.1.1 ?
  • If not, in each PC can you see the SVI in the ARP cache of the PC?
  • If not, do the switches agree on who is root of the Spanning Tree for each VLAN?
Kevin Dorrell
Luxembourg
i.e.
Parvesh
I found out what's wrong.
I've set to RSTP and because of that, its layer 2 STP shutting down one ports regardless of VLAN.
Cheers,
Elvin
