unable to create ip vrf on 3850
Saed Eldin
Dear All
I have to create vrf on my switch 3850 , but i got error " feature not enable".
Switch Ports Model              SW Version        SW Image              Mode
*    1 56    WS-C3850-48U       03.06.05E         cat3k_caa-universalk9 INSTALL
license: ip base.
Is there any solution to accept this command.
Not aware of that command with right-to-use at the end again usuall its all , my 3850s only have these options below but you cant fully activate a license you don't have on the switch anyway , ipservices licenses are expensive as they allow BGP/PBR and other advanced feature sets , Cisco make a lot of money on their licensing
xxxxxx#license right-to-use activate ipservices ?
  all         Configure license on all the switches in the stack.
  evaluation  activate evaluation license
  slot        Specify switch numbe
5 Replies 5
you need 'IP Services' for VRF functionality.
is there any command can convert switch from ip base to ip services?.
thanks
You gotta pay for the license as it opens up way more features but you can enable an evaluation license for 90 days temporarily but after that you have to pay
this is the command from priv mode #
license right-to-use activate ipservices evaluation
what about the below command
licenses right-to-use activate ipservices right-to-use
