Unable to negotiate with x.x.x.x port 22: no matching key exchange
lmqtechnology
We are unable to SSH to some IOS 3750s since a recent SSH client upgrade.  We understand why this is happening but rather than force the client to use deprecated or weak ciphers wanted to know if the Catalyst 3750 supports the new required ciphers.
ssh admin@x.x.x.x
Unable to negotiate with x.x.x.x port 22: no matching key exchange method found. Their offer:
diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
We are running 15.2(4)
post the output of:
show ip ssh
This should tell you which ciphers your IOS supports.
balaji.bandi
If you running SSH version 2 you can re-key with new RSA or you can add below syntax :
ip ssh {server | clientalgorithm encryption {aes128-ctr | aes192-ctr | aes256-ctr | aes128-cbc | 3des-cbc | aes192-cbc | aes256-cbc}
check show run all (some command may be already configured as default with 15.X  code)
https://community.cisco.com/t5/security-documents/guide-to-better-ssh-security/ta-p/3133344
BB
Leo Laohoo
What exact version?  15.2(4)E train starts from 15.2(4)E until 15.2(4)E10.
