Unable to ping 1 internet site from edge router able to ping from other devices
mahesh18
Level 6
Level 6
Hi Everyone,
From My Router that connects to Cable modem i am unable to ping website 4.2.2.2
I am able to ping all other websites fines.
Same website i can ping from my pc and all other switches fine.
Router has only 1 ACL thats for NAT.
Need to know what elase i can check on router?
Mahesh
3 Accepted Solutions
When you explicitly specify the source it works but without it doesn't. Will have to see what source address doesn it pick up when you do ping 4.2.2.2.
define an ACL and do a dehug.
access-list 140 permit icmp any host 4.2.2.2
debug ip packet 140
look for the source when you try to ping and the path it takes to forward the traffic
Now it's clear what was the problem because your router used as source interface Lo4 with IP 4.4.4.4. And of course this doesn't belongs to you machine with 4.2.2.2 received your pings and then routed that packet to actual 4.4.4.4 machine on the Internet and of course it's not your router .
Also you need to remove this ACL under interface it was just for debugging purpose.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
That ACL was just for debuggin, you shouldn't be applying it to any interface.
Your loopback 2,3 &4 have IP addresses that are public and shouldn't be assigned to your router if they don't belong to you (unless you are working in test lab and not haing internet connection out.
As per logs, 4.4.4.4 is used somewhere else on internet and hence you don't get a response. Change those IPs to local schema if you are using those IPs without any specific reasons.
let me know if you need any further assistance.
PS: Don't forget to rate helpful answers
25 Replies 25
Reza Sharifi
Hi Mahesh,
Some websites block ping.  Can you access the site using HTTP? www..com
Reza
Hi Reza,
I was to ping it before.
This website 4.2.2.2 does not block pings.
2691Router#ping www.b.resolvers.level3.net
Translating "www.b.resolvers.level3.net"
From PC
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\manveer>nslookup 4.2.2.2
Server:  pd1nsc4.st.vc.shawcable.net
Address:  64.59.144.19
Address:  4.2.2.2
C:\Users\manveer>ping 4.2.2.2
Pinging 4.2.2.2 with 32 bytes of data:
Reply from 4.2.2.2: bytes=32 time=46ms TTL=51
Reply from 4.2.2.2: bytes=32 time=49ms TTL=51
Reply from 4.2.2.2: bytes=32 time=51ms TTL=51
Ping statistics for 4.2.2.2:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 46ms, Maximum = 51ms, Average = 48ms
C:\Users\manveer>
From Nei switch
3550SMIA# ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/48/52 ms
3550SMIA#
I can no tping it from router for some reason
thanks
mahesh
HI,
You are trying to ping by DNS name it looks like domain lookup turned off. But what if you try by IP address 4.2.2.2?
ip domain-lookup
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800c525f.shtml
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Hi Abza,
Here is update
2691Router(config)#exit
Translating "www.b.resolvers.level3.net"...domain server (64.59.144.18) (64.59.1
35.145) (64.59.128.114)
% Unrecognized host or address, or protocol not running.
2691Router#ping 4.2.2.2
Success rat
Mahesh
Hi Mahesh,
So, you can ping from the router using ip 4.2.2.2 but not using DNS name?
If yes, have you configred DNS on the router?
ip name-server x.x.x.x
ip domain-lookup
Reza
Hi Reza,
Success rat
There is no DNS  on router
MAhesh
Hi Mahesh,
Can you post sh run?
Reza
2691Router#sh run
2691Router#sh running-config
Building configuration...
Current configuration : 9488 bytes
! Last configuration change at 11:58:43 MST Sat Jan 19 2013
! NVRAM config last updated at 19:50:43 MST Thu Jan 17 2013
version 12.4
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
hostname 2691Router
boot-start-marker
boot-end-marker
no logging exception
logging count
logging buffered 4096 informational
no logging console
no aaa new-model
clock timezone MST -7
clock summer-time MST recurring
no network-clock-participate slot 1
no ip icmp rate-limit unreachable
ip cef
ip host 3550SMIA 192.168.5.2
ip host 3550SMIB 192.168.10.2
ip host 2950T 192.168.10.5
ip host 2650XM 192.168.4.3
ip name-server 64.59.144.18
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
login on-failure log
login on-success log
ipv6 unicast-routing
archive
log config
  hidekeys
path slot0:/configs/$h
write-memory
time-period 1440
ip tcp synwait-time 5
ip ssh port 2009 rotary 1
buffers tune automatic
interface Loopback2
description IBGP neighbour to Router 3550B
ip address 2.2.2.2 255.255.255.0
interface Loopback3
description IBGP neighbour to Router R4
ip address 3.3.3.3 255.255.255.0
interface Loopback4
ip address 4.4.4.4 255.255.255.0
interface Loopback6
description Tunnel0 Source IP
ip address 10.0.0.1 255.255.255.255
interface Loopback7
description LAN SEGMENT OF 2691
ip address 100.100.100.100 255.255.255.255
interface Loopback8
ip address 101.101.101.101 255.255.255.255
interface Loopback33
description IPV6 OSPF LAB
no ip address
ipv6 address FEC0:4::4/64
ipv6 enable
ipv6 ospf 110 area 100
interface Loopback133
no ip address
ipv6 address FEC0:1::1/64
ipv6 enable
ipv6 ospf 100 area 101
interface Tunnel0
description description GRE EIGRP TUNNEL TO R3
ip address 13.13.13.1 255.255.255.0
keepalive 10 3
cdp enable
tunnel source 192.168.5.3
tunnel destination 192.168.4.3
tunnel path-mtu-discovery
interface FastEthernet0/0
description WAN Connection to ISP modem
ip address dhcp
no ip redirects
no ip unreachables
ip accounting output-packets
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0
description Serial connection to 2650 on interface se/0/0
encapsulation frame-relay
ip ospf network point-to-multipoint
no keepalive
interface FastEthernet0/1
description Lan Connection to 3550A Switch
ip address 192.168.5.3 255.255.255.254
ip flow ingress
ip nat inside
ip ospf hello-interval 40
ip ospf priority 10
duplex auto
speed auto
interface FastEthernet1/0
description Lan Connection to 3550B Switch
ip address 192.168.6.3 255.255.255.254
ip flow ingress
ip nat inside
ip ospf authentication
ip ospf authentication-key 7 05080F1C2243
ip ospf priority 10
duplex auto
speed auto
interface Serial1/0
description Serial connection to 2650 on interface se0/1
ip address 192.168.2.1 255.255.255.0
no keepalive
serial restart-delay 0
interface FastEthernet1/1
description Backup Connection to 3550B Switch interface fa0/24
ip address 192.168.7.1 255.255.255.0
ip nat inside
shutdown
duplex auto
speed auto
glbp 30 ip 192.168.7.3
glbp 30 preempt delay minimum 120
interface Serial1/1
ip address 192.168.9.3 255.255.255.0
ip ospf network point-to-multipoint non-broadcast
no keepalive
frame-relay map ip 192.168.9.2 104 broadcast
router eigrp 100
redistribute connected
passive-interface Loopback7
passive-interface Loopback8
network 13.13.13.1 0.0.0.0
network 100.100.100.100 0.0.0.0
network 101.101.101.101 0.0.0.0
no auto-summary
router ospf 1
router-id 4.4.4.4
log-adjacency-changes
redistribute static metric 300 subnets
passive-interface Serial0/0
passive-interface Serial1/1
network 3.3.3.3 0.0.0.0 area 0
network 4.4.4.4 0.0.0.0 area 0
network 10.0.0.1 0.0.0.0 area 0
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
network 192.168.5.0 0.0.0.255 area 0
network 192.168.6.0 0.0.0.255 area 0
default-information originate
router bgp 6500
no synchronization
bgp log-neighbor-changes
neighbor 6.6.6.6 remote-as 6500
neighbor 6.6.6.6 password 7 020B05551D030A33
neighbor 6.6.6.6 update-source Loopback3
neighbor 100.100.100.100 remote-as 7500
neighbor 100.100.100.100 shutdown
neighbor 100.100.100.100 update-source Loopback2
no auto-summary
no ip classless
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 70.75.72.1
ip route 11.11.11.11 255.255.255.255 6.6.6.6
ip route 172.31.0.0 255.255.255.0 Null0
ip route 172.31.1.0 255.255.255.0 Null0
ip route 172.31.2.0 255.255.255.0 Null0
ip route 172.31.3.0 255.255.255.0 Null0
ip flow-export version 5
ip http server
ip http port 1025
ip http authentication local
no ip http secure-server
ip nat translation timeout 3600
ip nat inside source list 101 interface FastEthernet0/0 overload
logging trap debugging
logging 192.168.20.9
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
snmp-server community supersecret RO
snmp-server community public RO
snmp-server trap-source FastEthernet0/1
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps flash insertion removal
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmobile
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls vpn
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-messa
ge
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps rtr
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps vsimaster
snmp-server enable traps vtp
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps voice poor-qov
snmp-server enable traps voice fallback
snmp-server enable traps dnis
snmp-server host 192.168.20.9 version 2c supersecret
ipv6 router ospf 110
ipv6 router ospf 100
control-plane
banner motd ^CC
DO NOT LOG ON
^C
alias exec traffic sh ip nbar protocol-discovery  stats  bit-rate  top-n  10
alias exec proc show proc cpu | ex 0.00%__0.00%__0.00%
privilege exec level 5 show running-config
line con 0
exec-timeout 3000 0
logging synchronous
line aux 0
exec-timeout 0 1
login
modem InOut
no exec
transport output none
flowcontrol hardware
line vty 0 4
exec-timeout 600 0
logging synchronous
login local
rotary 1
length 500
transport input telnet ssh
escape-character 3
line vty 5 15
exec-timeout 600 0
logging synchronous
login local
rotary 1
ntp logging
ntp clock-period 17180580
ntp server 91.103.24.10
end
2691Router#$
Hi Reza,
Please see config above.
also i have ip dns server config on the router.
mahesh
Hi Mahesh,
The config looks good.
Can you try
clear ip arp 4.2.2.2
and also
clear arp-cache
And then ping 4.2.2.2
Reza
Hi Reza,
Tried still no luck.
MAhesh
Hi Mahesh,
Ok, couple more things
Can you shut the tunnel interface and try again?
and last thing
Can you reboot the router and try again?
Reza
Hi Reza,
Rebooted the router.
Removed and added ACL shut down the tunnel int still same thing.
Do not know what else i can try
thanks
mahesh
Hi Reza,
Here  is more update
when i ping from Edge router that connects to ISP on int fa0/0
here is info
2691Router#ping ip 4.2.2.2  source  fastEthernet 0/0
Packet sent with a source address of 70.x.x.x
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/52/56 ms
2691Router#
Jan 19 23:53:56.374 MST: ICMP: echo reply rcvd, src 4.2.2.2, dst 70.x.x..x
Jan 19 23:53:56.526 MST: ICMP: echo reply rcvd, src 4.2.2.2, dst 70.
Jan 19 23:53:56.578 MST: ICMP: echo reply rcvd, src 4.2.2.2, dst 70.
2691Router#
where IP 70.x.x.x is of fa0/0 interface of router that connects to isp
when i ping like this
Success rate is 0 percent (0/5)
2691Router#
Mahesh
Show output of edge router
sh ip route
traceroute 4.2.2.2
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
