unable to ping management port from switch
yogpatil
I have a CAT3850. Configured management port with internal LAN routable IP (so that i can access it from outside lab but still on intranet).
Switch is reachable from outside the lab, but when pinged from switch itself, ping doesn't work.
However, I also have a loopback interface configured for some reason. Could it be because of loopback and management both are configured ?
Loopback
interface Loopback0
ip address 5.5.5.5 255.255.255.255
Management port
switch#show ip interface b
GigabitEthernet0/0     172.19.XX.XXX   YES NVRAM  up                    up
switch#ping 172.19.XX.XXX
Sending 5, 100-byte ICMP Echos to 172.19.XX.XXX, timeout is 2 seconds:
Success rate is 0 percent (0/5)
When pinged from outside:
mac-laptop:$ ping 172.19.XX.XXX
PING 172.19.XX.XXX(172.19.XX.XXX): 56 data bytes
64 bytes from 172.19.XX.XXX: icmp_seq=0 ttl=246 time=8.514 ms
64 bytes from 172.19.XX.XXX: icmp_seq=1 ttl=246 time=3.800 ms
64 bytes from 172.19.XX.XXX: icmp_seq=2 ttl=246 time=4.686 ms
^C
--- 172.19.XX.XXX ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 3.800/5.667/8.514/2.046 ms
Mark Malone
the mgmt. port is not in a vrf is it just a thought ?
Loopback should have nothing to do with it , if its in vrf you need to ping vrf
interface GigabitEthernet0/0
 description ** Network Managment Interface **
 vrf forwarding Mgmt-vrf
 ip address 172.21.222.75 255.255.254.0
 negotiation auto
#ping vrf Mgmt-vrf 172.21.222.75
Sending 5, 100-byte ICMP Echos to 172.21.222.75, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Mark Malone
 negotiation auto
yogpatil
It worked for me. Thank you !!
I have a follow up question through. When I have to copy some new image file from remote FTP server (on 172 network), will it by default choose gig 0/0 interface ?
There is a feature called MPP but it's not fully operational yet in ios-xe even though the syntax is available ,it may work for ftp but I've had issues with ssh and TAC said it's not fully released yet ,I have a feature request raised but they can take months
The other option is to apply acls in and out to force traffic over that interface,MPP is a lot cleaner though only few lines syntax if it works for you
Off my head I think the cli command was control-plane host
It's really an ios-xr command
