Unable to ping/telnet to management interface of switch
Charlie Jones
Good morning,
A couple of weeks ago we upgraded about 50 access layer switches at a branch office.  All of them are WS-3560-24PS.  The switches were upgraded to IOS 12.2(55)SE6. Once the update was completed, all of the switches were reloaded to complete the upgrade.   One of the 50 switches showed up in our monitoring application as being down after the reload.  We had someone at the office plug in a laptop so we could console into it and the switch configuration looked correct.  The switch is working normally (PC's and phones working normally), but we cannot ping or telnet into this one switch.  Below is a breakdown of this site in terms of topology:
Core - 2 6509
Distribution - 2 3750g
Access - 3560 switches
Layer two looks to be running normally in that vtp is being updated and cdp is working as well.   The trunk interfaces from this switch to the distribution layer switch are up (each gig interface on this 3560 goes to one of the 3705g switches).
On this switch, I have erased the config and deleted the vlan.dat.  I reapplied the config and re-enabled VTP and this switch is still not accessible.  Any suggestions?
I should mention that the management interface is  vlan 1. I have tried giving this management interface a different IP address in case there was a duplicate IP and that does not work.  Other switches that were upgraded and connect up into this 3750g stack work fine.
36 Replies 36
I would like to go back to my question of yesterday about arp between the problematic switch and the upstream. The output of debug arp shows that the problematic router is generating requests for arp for the gateway address but not receiving any response. The output of debug arp on the upstream router shows that it receives the request from the problematic switch. It does not seem to show that the upstream sends any response. But I am not sure how long that debug was running. So I would ask Charlie to run debug arp on the upstream switch (preferable the switch that is the active router in HSRP). While the debug is running then do the ping from the problematic router. This should generate the arp request to upstream. Let the debug run long enough to be sure whether the switch is sending a response or not.
Rick
Rick
Charlie
CDP from previous posts:
Switch 1
Device ID            Local Intrfce         Holdtme   Capability    Platform   Port ID
CHI-3560-2602       Gig 1/0/2             162            S I      WS-C3560-2Gig 0/1
Switch 2
CHI-3560-2602       Gig 1/0/2             147            S I      WS-C3560-2Gig 0/2
Now from you current posting:
UPLINK SWITCH 1 -
Only one trunk interface is up
GIG1/0/1 - this is not your link to the problem switch as stated in your previous cdp post
Port        Mode         Encapsulation  Status        Native vlan
Gi1/0/1     on           802.1q         trunking      1
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     1,851,853 Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     1,851,853
UPLINK SWITCH 2 -
Only one trunk  interface shows up
Gi1/0/1     1,26,126,850
Problematic Switch
#sh int trunk
Gi0/1       on               802.1q         trunking      1
Gi0/2       on               802.1q         trunking      1
Gi0/1       1,25,27,29,31,125,127,129,131,503,851,853,935,977,985,999,1001
Gi0/2       26,28,30,32,126,128,130,132,830,850,984,990,998
Port        Vlans in spanning tree forwarding state and not pruned -
I can see some anomalies regards trunking and stp:
How are these two Uplink switches connected to the problem switch? I only see 1 trunk on each uplink switch and this does not seem to be going to the problem switch?
Can you post your running config in file attachments for all 3 switches:
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
Good morning,
It's been awhile since I've had a chance to work on this, and today I have an update of sorts.  We decided to swap out this problematic switch in the hope it was a problem with the switch.  Unfortuntely, this did not correct the problem.  The problem must lie somewhere else within this office.
Here are the configs for the trunks and the vlan interface on the problematic switch:
interface GigabitEthernet0/1
switchport mode trunk
switchport nonegotiate
speed 1000
duplex full
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
rmon collection history 10101 owner campusmanager buckets 10 interval 300
interface GigabitEthernet0/2
speed 1000
duplex full
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
rmon collection history 10102 owner campusmanager buckets 10 interval 300
interface Vlan1
ip address 10.19.0.112 255.255.255.0
ip default-gateway 10.19.0.1
Here is the config of switch 1 uplink that this switch trunks to
interface GigabitEthernet1/0/2
speed 1000
duplex full
queue-set 2
mls qos trust dscp
auto qos voip trust
Here is the config for the switch 2 trunk:
speed 1000
duplex full
queue-set 2
mls qos trust dscp
auto qos voip trust
To give you an idea of the network topology, it follows Cisco's practice of a core/distribution/access model.
Core - Pair of 6509
distribution - Pair of 3750G
access- 3550 switches
At this access layer, there are other switches that are trunked up to the 3750G's, and those switches are working normally.  Also, there are PC's/phones plugged into this switch, and those are working normally.  In fact, I tested pinging one of the hosts on this switch, and I can ping the host from somewhere else on the network.  However from the problematic switch, I cannot ping this host.
Problem solved.  I ended up looking at a configuration from an existing switch at this branch, and the switch having the problem had the command "vlan dot1q tag native".  As soon as I did a no vlan dot1q tag native, the problem was gone.
Charlie
thats great news, but unfortunate in a way that it was not found eariler
Not my text but the; “vlan dot1q tag native” which will prevent the double-encapsulation  attacks.  This command globally works on all switchport trunks on that  entire Ethernet switch.  This command will make sure that the native  VLAN is always tagged on every trunk on the switch.  This is a great  best practice and takes care of the issue with a single command.  This  command should be entered in every switch in the campus." (my bold)
This caused every untagged ingress frame is dropped, so the traffic replies were not reaching the control plane of the switch.
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
- Always vote on an answer if you found it helpful
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
If this is configured globally, then what would have been the fix to keep this command active?  Would we need to add something to the trunk ports on this switch?  Now, I'm curious.
No, i've checked it out, and i've not seen a way to disable on a per-port basis. It's all-for-one, or none-at-all
Really gald you located the issue.
