Unable to SSH directly to Switch(Catalyst 3850)
farhanp
I have this weird issue where the switch majority of times doesn't allow SSH directly into it from LAN but if SSH'ed through VPN or through another network devices, it always allows.
version 15.2
no service pad
service password-encryption
hostname xxxxxxx
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered 4096000
enable secret 5 xxxxxx
username admin privilege 15 secret 5
user-name lobby
creation-time 1450511320
privilege 15
password 7 xxxxxx
type lobby-admin
user-name temp
creation-time 1470885033
privilege 15
password 7 xxxxxx
type lobby-admin
aaa new-model
aaa authentication login default group radius local
aaa authentication login local_webauth local
aaa authorization network default local
aaa authorization network local_webauth local
aaa authorization credential-download default local
aaa session-id common
clock timezone IST 5 30
switch 1 provision ws-c3850-24t
ip routing
no ip domain-lookup
ip domain-name xxxxxxx.in
qos wireless-default-untrust
qos queue-softmax-multiplier 100
access-session mac-move deny
crypto pki trustpoint TP-self-signed-1152785948
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1152785948
revocation-check none
rsakeypair TP-self-signed-1152785948
crypto pki certificate chain TP-self-signed-1152785948
diagnostic bootup level minimal
port-channel load-balance src-mixed-ip-port
service-template webauth-global-inactive
inactivity-timer 3600
service-template DEFAULT_LINKSEC_POLICY_MUST_SECURE
service-template DEFAULT_LINKSEC_POLICY_SHOULD_SECURE
service-template DEFAULT_CRITICAL_VOICE_TEMPLATE
voice vlan
spanning-tree mode rapid-pvst
spanning-tree vlan 1-4094 priority 4096
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
parameter-map type webauth global
virtual-ip ipv4 1.1.1.1
parameter-map type webauth WEB-AUTH
type webauth
lldp run
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface Vlan5
ip address xxxxxx 255.255.255.0
interface Vlan6
interface Vlan100
ip address 192.168.10.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.5.254
ip ssh authentication-retries 2
ip ssh version 2
ip ssh server algorithm mac hmac-sha1-96 hmac-sha1
ip ssh server algorithm encryption aes256-ctr aes192-ctr aes128-ctr
line con 0
privilege level 0
password 7 xxxxxx
logging synchronous
login authentication local_webauth
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 xxxxxx
transport input ssh
line vty 5 15
password 7 xxxxxx
transport input ssh
ntp server 192.168.5.254 source Vlan5
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
wireless mobility controller
what is the error message you are getting when its SSH is blocking. is it give some encryption errors? or just connection time out?
Good luck
KB
Tried using SecureCRT and Putty and it times out. Times out on telnet as well. And I did change line vty to transport input all for testing telnet.
