unable to stat flash/: permission denied
Hey trying to delete the config file on my Cisco 2950.
But i get this error Message: unable to stat flash/: permission denied after doin this commands
switch: flash_init
Initializing Flash...
flashfs[0]: 410 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4933632
flashfs[0]: Bytes available: 2807808
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
switch: load_helper
switch: dir flash
switch: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
                  bs[3]: (read-only)
switch: flash_init
...The flash is already initialized.
intel_28fxxx_write_bytes: flash busy error
flashfs[0]: writing to flash handle 0x80c5c7e4, device 0, offset 0x40000, length 0x208: Operation Fa
iled
flashfs[0]: sector ptr: {0x2, 0x79}
flash:env_vars.tmp: I/O error
The filesystem containing the variables may not be initialized yet.
switch: dir flash
5 Replies 5
Arumugam Muthaiah
Hi Sebastian,
Please make sure to type a colon ":" after the dir flash.
The switch file system is displayed:
switch: dir flash:
Directory of flash:/
2    -rwx  1803357                  c3500xl-c3h2s-mz.120-5.WC7.bin
Refer:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Hey i tried that now and i got this message back
switch: dir flash:
Unable to open flash:/: device busy
mahmoodmkl
Level 7
Level 7
i suggest tht u format u r flash reupload the image
And how do i do that? Kinda new to this
U need to enter format flash:
This will prompt you tht this will erase all the data on flash u need to confrim it.
Once the flash is formatted u need to upload the IOS through Xmodem which is to transfer the image through console cable.
