Unable to upgrade Catalyst 2960 through USB
JAISONTHOMAS
Folks, I am trying to upgrade a 2960-x using USB, I have formatted the drive to FAT16 and copied the files c2960x-universalk9-mz.152-7.E12.bin and c2960x-universalk9-tar.152-7.E12.tar.
However when inserting the USB stick into the switch, I am getting the following error,
Sw_test1#
Jul 5 15:41:07.477: %USBFLASH-4-FORMAT: usbflash0 contains unexpected values in partition table or boot sector. Device needs formatting before use!
Sw_test1#
Jul 5 15:41:07.477: %USBFLASH-5-CHANGE: usbflash0 has been inserted!
Sw_test1#
Sw_test1#copy usbflash0:c2960x-universalk9-mz.152-7.E12.bin flash:
Destination filename [c2960x-universalk9-mz.152-7.E12.bin]?
%Error opening usbflash0:c2960x-universalk9-mz.152-7.E12.bin (Invalid DOS media or no media in slot)
Sw_test1#
Any idea whats going on and how to sort this? Thank you.
10 Replies 10
Mark Elsen
  - The USB stick is corrupt ; try another one , or format it first as was pointed out,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
tried another usb
Formatted it to fat16
same error
What firmware is the switch currently on?
Switch Ports Model SW Version SW Image
* 1 54 WS-C2960X-48LPS-L 15.2(7)E10 C2960X-UNIVERSALK9-M
Use a different brand of USB flash drive.  Preferably, 8Gb or smaller.
  - @JAISONTHOMAS   Have a try with   fat32
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
I strongly recommend using the switch and formatting the USB flash drive.
And I would never recommend anyone "copy the BIN file" as a method to upgrade the switch firmware.  Download the TAR file and use the following command:
archive download-sw flash:filename.tar
JAISONTHOMAS
@Mark Elsen @Leo Laohoo  At this point, I am convinced that its not an issue with the USB stick. Because I have formatted the same stick to FAT32 and upgraded a Catalyst 9200 successfully. So I will try 2960 as well with FAT32 and update you folks. Cheers
 - @JAISONTHOMAS   If the problem persists , try the same USB on your PC and check if you get the same errors or not,
  M.
       Beauty and terror
      Just keep going
       No feeling is final
pieterh
can you try formatting  the usb IN the 2960 switch ?
