Uncast flooding on collapsed distribution and core.
Mark Williams
In an environment where there is a dedicated router connected to dedicated distribution switches, I understand the need to configure the MAC AGING and ARP timers on each device.
However, in an environment where the distribution switch and router are collapsed (Eg a 3750), does this still need to be done? Will not the ARP table and MAC table always be in sync?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information  contained within this posting without consideration and with the  reader's understanding that there's no implied or expressed suitability  or fitness for any purpose. Information provided is for informational  purposes only and should not be construed as rendering professional  advice of any kind. Usage of this posting's information is solely at  reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
It depends on whether your using a 3750 as a single L3 device or a separate L3 devices.  If you're running a collapsed core with multiple devices, such that ingress and egress paths can differ, unicast flooding can still arise if MAC aging and ARP timers aren't sync'ed.
