02-01-2012 06:54 AM - edited 03-07-2019 04:40 AM
Hi All,
I'm having weird problems with both of our 3560G switches. When I take a look at the port statistics via CNA I see a lot of underzised errors on trunk ports.
When I take a look at the CLI via sh interfaces counters errrors I don't see any underzised errors.
I know that this was a software bug in several versions, but we are running 12.2(52)SE and as far as I know that isn't an issue with this version.
The configuration of the ports are like this:
interface GigabitEthernet0/4
description Uplink to SWIBLA06 Port 22 Slot 6
switchport mode trunk
switchport nonegotiate
speed 1000
duplex full
channel-protocol lacp
channel-group 6 mode passive
spanning-tree portfast trunk
end
SWICOR02#sh run int gig0/3
Building configuration...
Current configuration : 276 bytes
interface GigabitEthernet0/3
description Uplink to SWIBLA06 Port 21 Slot 6
speed 1000
duplex full
these are uplinks to a GBE2c switch in a HP Chassis
Does this problem sound familiar to anyone?
Thanks!
Geert Reijnders
07-23-2012 03:27 PM
Hi Geert,
I have the exact same issue, did you come across a solution to same?
Regards Denis
07-23-2012 11:27 PM
unfortunatly not. however, I created a workaround for this customer. Via SNMP . I know it isn't the solution, but I didn't had the time to invest this issue any further.
07-23-2012 11:32 PM
Thanks for the prompt reply, just one further question - were these errors causing any impact on performance?
